Question about Dell Dimension E521 AMD Athlon 64 X2 Dual-Core 3600+ , 1 GB DDR2 SDRAM , 250 GB EIDE SATA H... PC Desktop
My dell E521 is now getting STOP errors after installin a video c
Hi, i have an dedll dimension E521 and i just hade a video card thats sucked so i found the good stock one and poped it in along with getting drivers, but now when i play a game and somtimes just let it sit i get a blue screen error that says this... (i was playing a game called garrys mod. a mod from half life 2 from steam).... *******************************************************************************
* Bugcheck Analysis *
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: b2a60000, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: b64c5d62, address which referenced memory
Debugging Details:
WRITE_ADDRESS: b2a60000
CURRENT_IRQL: 2
FAULTING_IP:
sthda+18d62
b64c5d62 f3a5 rep movs dword ptr es:[edi],dword ptr [esi]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: Idle
LAST_CONTROL_TRANSFER: from b64c7f25 to b64c5d62
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
80550398 b64c7f25 00000000 b2a60000 89d00c00 sthda+0x18d62
805503d4 b648c263 80550400 00001440 80550404 sthda+0x1af25
80550414 b648c704 00005040 8055b0c0 ffdff000 portcls!CPortPinWaveCyclic::RequestService+0x296
80550428 80545c4f 89232930 89232920 00000000 portcls!CServiceGroup::ServiceDpc+0x26
80550440 8055ae60 ffdffc50 00000000 8055ae60 nt!KiRetireDpcList+0x61
80550450 80545b34 00000000 0000000e 00000000 nt!KiIdleThread0
80550454 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x28
STACK_COMMAND: kb
FOLLOWUP_IP:
sthda+18d62
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: sthda+18d62
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: sthda
IMAGE_NAME: sthda.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 44c900cc
FAILURE_BUCKET_ID: 0xD1_sthda+18d62
Followup: MachineOwner
  • 1 more comment
  • hacks14 Sep 29, 2009
    sorry the DMP code dident paste right
    Arguments:
    Debugging Details:
    CURRENT_IRQL: 2
    FAULTING_IP:
    sthda+18d62
    BUGCHECK_STR: 0xD1
    PROCESS_NAME: Idle
    STACK_TEXT:
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    sthda+18d62
    MODULE_NAME: sthda
    my specs are athlon x2 dual core with 2 gigs of ram and a 320 gig HD
    Well how would i go about doing this in my BIOS i looked and dident see any IRQ option
    Sergeant:
  • 338 Answers
There is an IRQ conflict(internal adressing all the hardware parts)
you may want to set all the IRQ options in BIOS to auto and let the BIOS handle the IRQ adressing, disable the plug'n'play OS feature too so that the computer hardware manages the IRQs instead of windows. The blue screen is a sign that windows is causing problems, but done the way described this no longer will appear.
good luck
Posted on Sep 29, 2009
Testimonial: "thx but i still dont know how to FIX the problem please help"
  • Andrej.cet Sep 30, 2009
    enter bios by pressing Del or F1 or F2 button while booting(before windows kicks in), in BIOS menu change the settings as advised, leave saving changes(press F10), reboot, done
I have a Dell Dimension E521. I inserted a SD memory card into the SD card slot and nothing happens. The slot is not showing up under My Computer. I'm trying to transfer pictures from my computer to the SD...
check the device manager if it is showing there ? if with an error then u need drivers .. if it does not show up there then there is a problem with the memory card reader ..
Oct 24, 2010 | Dell Dimension E521 PC Desktop
Dell E521 getting no video from the board. repair guy say's I need a new motherboard.
Could be but you could also try a PCI video card, much cheaper, you may even be able to borrow one just to confirm the problem.
Also, I suggest check all your video drivers are up to date.
Apr 10, 2010 | Dell Dimension E521 AMD Athlon 64 X2...
Help! My dell dimension E521 will not boot after
Its seems like your RAM is not working properly, so once you replace the this RAM and check it, you problem should be resolve.
Regards
Ashly
Feb 01, 2010 | Dell Dimension E521 PC Desktop
MY DELL DIMENSION E521 WONT BOOT WINDOWS AFTER STARTING UP, I WAS TOLD THAT THE VIDEO CARD COULD BE BAD, WHERE IS THIS LOCATED IN MY PC AND CAN i USE ANY VIDEO CARD TO RPLACE THIS?
Hello, if you were told by an expert tha you need a video card, here what you need:
1: You do not have a slot card type video card in your system( Dimension E521) your system has on board video, which you can not remove from the system but disable it.
2: Your system has PCIe x16 slot that can be used for new video card.
3: Link below will give you a list of PCIe x16 video cards, you can pick and choose according to your needs. Do you need DVI (digital connection, does your monitor has a white port in the back or just the blue one?), or regular VGA (blue port) is enough, do you need HDMI etc...
bottom line is any of those video card will work.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000048%201069609641&Description=pci%20express%20video%20card&name=PCI%20Express%20x16&ActiveSearchResult=False
4: I am assuming you have never done this before so before you open up computer and start taking things apart go to the link below and download service manual for Dell Dimension E521 ( I selected the model for you so you don't have to look for it :-) )
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/index.htm
5: In the service manual link there are several Sections like:
Before You Begin
About Your Computer
Technical Overview
Specifications
Advanced Troubleshooting
System Setup
Removing and Installing Parts click on each one and read about it first to familiarize your self with the system.
6: Once you feel confident enough remove the power cable from from computer.
-> open computer cover
-> follow instructions in service manual under
->Removing and Installing Parts
-> Cards
->PCI Express Cards
-> Installing PCI express card.
-> Close computer cover
-> plug monitor cable to new card
-> power on the computer
-> if Picture quality is bad that means card was not properly recoginzed, install drivers from the CD that came with the video card.
I hope this helps, if you get stuck at any step or not clear feel free to post back.
Kind Regards,
Amar Sondhi
Feb 01, 2010 | Dell Dimension E521 (D10E16) PC Desktop
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
I have a Dimension E521 and i get a crash wit a stock vid card
uninstall your video driver then update your driver for your stock video card
Oct 04, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
DELL PART # DN804 For E521 computer
Hi
Dell Part # DN804 is PCI-e ATI Theater 650 Pro Combo Analog/Digital TV Tuner and it is compatible with Dell Dimension E521.
The ATI Theater 650 Pro PCI-e card is available in two form factors - Low Profile or Full Height. Dimension E521 is compatible with Full Height cards only. It is important that you ensure the you receive a full height card.
Check Installing a PCI Express Card for help installing the hardware. Next install required software/drivers.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1080274
Mike
May 03, 2008 | Dell PART NUMBER CARD NTWK PCI TR IBM 16/4...
Dell Dimension E521 AMD Athlon 64 X2 Dual-Core 3600+ , 1 GB DDR2 SDRAM , 250 GB EIDE SATA H... PC Desktop Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
