Question about GE Washing Machines
GE WWSE3160 Washer. Hot H2O flows, cold doesn't- hoses work ok.
I have a GE Model WWSE3160 Washer. The hot water fills, but cold water doesn't, so the cycle can't complete because the tub does not fill completely. I checked the hoses, and replaced them for good measure... but still having the same problem. Hooking up the hot to cold and cold to hot I can do a load with no problem (except have to do all washes and rinse in HOT water), so I feel that the issue is in the valve inside the machine and not the hoses, and that the valve inside may need to be replaced. I would like to attempt this myself but need to know how to order the right part and how to remove the old one properly! Any suggestions?
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Posted on Jan 21, 2009
  • 117 Answers
SOURCE: Washer only fills with hot water
Probably a bad water inlet valve. To verify, you would have to check continuity at the valve.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Posted on Jun 24, 2009
jsrock516
  • 5911 Answers
SOURCE: Rinse cycle water flow slow
This problem is commonly attributed to a water inlet valve (also known as a "mixing valve") that is going bad. The water may appear to flow better during the intial fill cycle, because BOTH solenoids (HOT and COLD) are typically used during the initial FILL cycle. However, nearly all washers use a cold water RINSE. This means only one solenoid is energeized during the rinse cycle which reduces the water volume even more.
If you live in an area that has hard water, or if you use well water, the inlet valve and/or fill hose sediment screens can become clogged with sediment, calcified deposits and rust resulting in a restriction of water flow. You can try cleaning the sediment screens and the water inlet valve in a 50/50 solution of distilled vinegar and hot water to see if you can dissolve any sediment or deposits. Removing the valve from the washer and allowing it to soak in the solution for about 30 minutes, then flushing it with clean water can sometimes return an inlet valve to normal operation. If cleaning the valve does not work, however, you will need to replace it. The following link explains how:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list have helpful exploded view diagrams to assist you with locating and properly identifing any parts you may need. If the model number you listed this question under is correct, the Water Inlet Valve number is 285805 and is listed as item 18 under the "Controls and Rear Panel" parts listing. The average price is less than $20.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Posted on Jul 14, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Model A511 Cold water will
Hi and welcome to FixYa, I am Kelly. Your testing of the solenoid was good. My question is this... when the timer stops do you still get the magnetic attraction? If I interpet this correctly; the answer is no. So we are dealing with a power problem. Power comes from the timer straight to the COLD solenoid. (Blue wire)
http://www.appliancepartspros.com/sect/i/e/j/iejjijajjf.gif (wiring diagram)
Power comes in to the TIMER from the lid switch on the red wire of terminal 12. It is supposed to be then routed to Yellow wire terminal 3 and the internal contacts of the timer (buss 14) connect power to the BLUE wire 5B. If your not getting power at the timer 5B / Blue wire lid closed the problem is inside the timer. Just make sure the timer connections discussed above are correct ON the timer.
Maytag PN 2.5639 timer NEW price is around $147.00 for factoryoriginal Used Avg $35.00. Your choice if you need a timer.
2-5639 +Maytag (Net image search)
Thanks for choosing FixYa,
Kelly
Posted on Jul 19, 2011
H2O supply and Tub will not fill in Ge Washer
First make sure someone didn't turn off the supply valves where the washer hoses are attached to. If both are on, then try to fill machine and switch between hot and cold water. If one of the 2 temps works, the other half of the fill valve is bad. The fill valve is the part where the hoses attach to the back of the machine. It is a 2 part electric valve with 2 electric coils on the valve. Could be one coil is bad or possibly the filter screen is blocked on one side. Screens can be checked and looked at by removing hoses and looking inside end of valve. If coil is bad, complete valve needs replaced. Easy exchange, a few screws, 4 wires, and a small hose leading to inside of machine.
Feb 22, 2015 | GE Washing Machines
Mah 6700 is stopping after 1 minute with a reading of NF
Did you check the screens in the watervalve when you removed the supply hoses? They can crud up over time and restrict the flow. Clean them in-place with a toothbrush and spray bottle. Reconnect hoses and test. While testing move temp switch from HOT to COLD to WARM settings and observe flow of water and temp of water in each position. Cold may flow a little faster than HOT but should be close to same flow rate. WARM however should have twice the flow rate of hot and cold temps seperately. Let me know what you find.
Jan 21, 2013 | Maytag Neptune Washing Machines
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
My GE washing machine just buzzes instead of filling with water, spin and agitate work fine.
Providing that the water supply is OK with no kinks or squashed hoses and the taps are fully turned on, this is symptomatic of a malfunctioning water control valve- the hot water one if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Mar 21, 2011 | GE WBSR3140DW Top Load Washer
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
Washing Machines Logo
134 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
