Question about Goodman GMS90703BXA Heater
No Heat The fan kicks on and blows cold air the sensor light flashes 3 times on the board. The fan is the only thing running
  • 1,420 Answers
3 flashes indicate an issue with either the inducer, pressure switch, plugged condensate drain or a venting restriction.
Clear all debris from the exhaust and intake air piping. Make sure they are not drooping anywhere.
Check the pressure switch and the rubber hoses for blockage.
Blow out the drain line that evacuates the condensation.
On the inducer motor housing, un- plug the rubber hose going to the pressure switch and check to see if there is suction when the motor is running.
Make sure your air filter is clean.
Listen to the inducer motor as it turns for gurgling or any other abnormal sounds.
To make the heater run while you have the cabinet open, tape down the door safety switch. Remove the tape after diagnosos.
Posted on Dec 19, 2007
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
My Home Ac Unit Is Not Blowing Any Air
This sounds like the fan not turning during cool. You will have to check the fan relay for power during the cool cycle. The fan relay is run by the low voltage side, but still there is hi voltage present. When in heat the power goes thru the relay on one set of points then in cool goes thru the opposite side. You should have a digram present, and then on the main circuit board there is a code light. Check the light for blinking or (flash) read the bottom of the board for the code ( very small print)
May 17, 2010 | Goodman CKL24AR24 Air Conditioner
I have a 61" projection tv. It shuts off by itself, usually 2-3 times in a short period then usually not again. The only thing I notice different than if I shut it off, is the lamp light flashes several...
You might want to try blowing it out with air, I have a toshiba that has had a similar problem and that always fixes it for a year or so. The problem is caused by the small cooling fans on the circuit boards, they get clogged and don't cool the board properly. The startup problem is also linked to the fans, they must run at speed or the board shuts down. I used an air compressor and took the tv to the garage to blow it out, you will need to take the back off and blow it our really good, and make sure to get ALL the small and large fans really clean, mine has four fans. Hope this helps....GOD BLESS...Randy
Nov 07, 2017 | Samsung HLT6187SAX 61" DLP HDTV
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
The furnace attempt to light, you can see the
The flame sensor is not sensing the flame. Google "flame sensor"
May be an adjustment or control board problem.
Dec 08, 2009 | York Furnace Draft Inducer Blower Fasco #...
98 v6 mustang is over heating its not the thermostate or fan
Several things ... best guess, in order:
1. (very likely) Radiator fan is not blowing (turn on car and a/conditioner.
When compressor kicks in, the radiator fan must blow). If it ims not blowing,
the radiator fan motor may be burned out ($40).
2. Check / replace "cooling fan" fuse ($1) and / or "cooling fan" relay switch
($7).
3. Radiator clog (possible)
Hope this helps!
Sep 22, 2009 | 1998 Ford Mustang
Will not blow cold air
pls check your remote setting
Apr 27, 2009 | Heating & Cooling
Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Apr 18, 2009 | Fujitsu 24R1 Air Conditioner
Goodman GMS90703BXA Heater Logo
168 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Dennis Boxerman
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
