Question about Digi Televison & Video
Remote power button lights up but pvr does not respond
  • 19,396 Answers
The receiver is in protect mode.
That happens when there is an internal fault, or when the protection circuit kicks in because of a wrong voltage.
Try disconnecting power cord and all cables, wait ten minute to allow power to drain completely, and reconnect.
If On reconnect unit is still dead , then the receiver must be take apart and tested by a technician to find the fault.
It would be the same on a TV.
Posted on Sep 29, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: PVR-9150T only responds to remote for about a minute and then only after power off and back on
I have same problem today. Must be a data problem sent with the listings. My remote works for a minute or so then just freezes. Guess we can just wait. Shame I've formatted my HD.
Posted on Dec 14, 2011
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Dec 14, 2011 | Humax Televison & Video
I have a Motorola DCT6416 PVR. Dog layed on remote and de-programmed. I can't find the program code to fix my remote control.
are you sure its not something simple like the remote is in the wrong mode. what lights up on the remote when you push buttons?
what isn't working? the cable box not responding? the tv not responding? nothing?
RCN's motorola code is 002 (actually i think the new remotes may be different), TV code could be anything.
FYI: battery cover on remote sometimes has directions for code search
hope something here helped
Apr 19, 2011 | Motorola Televison & Video
I used shift to us the remote control with the secondary TV. Now i cannot get it to correspond with the main tv. How do I fix the problem. Thanks
If u stil hve the manual, plz consult it. OR u press n hold shift, pres ur device button (tv), indicator light starts blinking, pres n release ur search/power button continuosly, whn u get response from ur tv, leave it 4 a few seconds, the light goes off n ur remote is set again.
Apr 10, 2011 | Universal Remote Control Dish Network...
I changed the batterys in the reciever remote as the system sid batterys where low now I cannot get the remote to respond
Ensure that the batteries are inserted the right way, if they are not the remote will not get power.
Make sure to hit the STB button and then press the POWER button.
Hope this helps!
Mar 07, 2011 | Bell Televison & Video
Humax PVR 9200T nolonger responding to controls on machine or remote.
1. Power off at the rear
2. Disconnect Aerial
3. Switch ON
4. If the unit can then be switched on carry out a Default setting
5. When the unit restarts insert the aerial cable so there is signal when the auto search appears.
Also, believe it or not, check your batteries in the remote control (seriously).
Apr 27, 2010 | Televison & Video
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
I have the Onkyo 706 with remote RC-717M. My remote just suddenly started to malfunction. The volume up is turning it down and vice versa. The power button to shut the receiver off is doing the function...
Have you tried resetting the remote? According to the manual (page 101), press and hold the RECEIVER button, press the AUDIO button, wait approx 3 sec. until RECEIVER highlights and finally press RECEIVER again. Of course if you've programmed a remote control code for your PVR in the RC-717M, you'll have to do it again.
Oct 18, 2008 | Onkyo Audio Players & Recorders
Televison & Video Logo
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
