Question about Mtd Garden
Will not start, cannot even be pushed to another location (wheels seem locked up)
  • 472 Answers
SOUNDS LIKE THE BRAKE IS STUCK YOU MAY WANT TRY MOVEING THE BRAKE BY HAND ON THE SIDE OF TRANS THE STARTING THING I NEED TO KNOW MORE ABOUT IT WHATS IT DOING OR NOT DOING
Posted on Sep 30, 2009
Husqvarna neutral lever is not locking the tires.
Stating the obvious you should not be able to push the machine with the bypass lever in, so assuming the lever is going right in ( you may need to clear any grass away from the actuating lever on the gear box ) there has to be an issue with the hydo itself.
May 14, 2018 | Husqvarna Garden
Instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
How can I fold?
Kindly follow the steps below on how to fold the stroller:
Apr 16, 2016 | Baby Gear
Why are the wheels locked on Jeep ? Won't even roll in Neutral!
so you did get the key to move enough and brakes on to move the shifter to neutral.
are you an the arctic circle, (i have a buddy there,) pop 100.
hand brake off,
park dis-engaged, neutral
if it dont move the brakes are locked
or one axle bearing is seized.
so jack up each wheel 1 by 1, and see if it turns
on flat ground, and other wheels chocked so car can not roll.
i bet all 4 can spin,
and you just can push this heavy pig. i can barely do my wrangler.
you tried to hand push a car?
lets work no starts
does it crank over in park/?
does the engine crank fast , while in the start position?
my guess is the park lock out is fooling you.
most cars the park lock up is complex now.
its really in park not neutral.
and the reason , blown fuse. my guess.
tell all that works key, on in details
head lights, not just my lights work say HEAD
they draw like 10 amps of current, about 100x more that other lights.
even better
does engines start with jumper cables, jumped from a running car.
donor car.
can AAA start car?
if yes, post that first. all else is effect not cause.
Aug 28, 2014 | 2006 Jeep Liberty Sport
I am having trouble reinstalling my steering wheel pressure plate after having replaced the ignition,,, any suggestions?
Steering wheel pressure plate? Are you talking about the metal plate with notch's cut out all the way around the edge? If so, that would be the steering column lock plate. If the parts below it are not installed properly, it will not allow itself to seat properly. It also will only go in one way due to the splines on the steering shaft and on the inside of the hole in the center of the plate. You will also need a special tool that applies even pressure to push the plate down to compress the spring so that you can put the retaining clip on. You should also have the ignition lock turned to the run position so that the rod or pin isn't trying to push the plate back up. Hope we're talking about the same thing here.
Feb 01, 2014 | 1991 Oldsmobile Cutlass Ciera
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It seems when I pushe button to start nothing
Some fault in the dishwasher is causing it to believe the door is not locked.
I would check the door lock.
check this youtube video out for the location of the door switch.
http://www.youtube.com/watch?v=2CqFZ-Ud0nE&feature=related
(quality of video may not be the best but gives an idea of its location).
If you can give me the exact model number I can find out more details of the problem you are having.
May 12, 2010 | Frigidaire Professional Series 24 in....
My riding mower is stuck in gear. I can shift
If the wheels aren't facing straight forward you may have broken an axle.
May 18, 2009 | Garden
Steering wheel was turned in process to locate battery prior to knowing that positive and negative prongs where located under the hood for more convient jump start. after recieving an intional charge and...
The ignition key and lock cylinder operate a gear and lever type of mechanism within the steering column. If the gear jumps out by one tooth, or has been assembled incorrectly, it will cause the steering wheel to remain locked and the push rod that activates the ignition switch (located near the bottom of the column) will not function correctly. This can be very tricky to solve, and should be serviced by an experienced technician.
Sep 27, 2008 | 2001 Chrysler Concorde
Garden Logo
136 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
