Question about Panasonic DVD-LS90 Portable DVD Player
Player does not read disc-code HO3
DVD player does not read disc (code HO3) I also think that the CD does not spin, I do not here a hum.
I followed a few, of the already suggested answers. The first one I tried was to open up the back and use compressed air to blow out lint, food crumbs and dog hair that had found there way into the machine. This seem to have worked just fine. Now the machine is working, much to my daughters delight.
Posted on Oct 05, 2009
What does it mean code H03 for my Panasonic DVD-LS90
Posted on Oct 15, 2009
Won't read regular dvd's
I think local disc cannot read your DVD. Put quality disc into your DVD.
Feb 21, 2014 | LG BD610 BRay Disc Player
Whenwe try to use dvd it reads bad disc used dvd
Hi did you try cleaning the washer that spins the cd they often get glazed and slip causing the cd to spin at a low rpm causing the bad disc error.
Feb 01, 2010 | Daewoo DV-6T955B DVD Player/VCR
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
HO3 error panasonic DVD-LS80 disc will not play?
como hacer funcional el lente del equipo, tengo un error h03 VDV-LS80
May 26, 2009 | Panasonic DVD-LS80
Error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its patch. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
Error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Aug 04, 2008 | Panasonic DVD-LS90 Portable DVD Player
Code ho3
Jan 05, 2008 | Panasonic DVD-LS90 Portable DVD Player
UUURRRG
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
Unable to detect discs
The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A)
Difficulty reading cd, if it does read the sound is strange and sticks
Replace C101 (1000uF/16v)
Nov 24, 2007 | Philips DVD750VR DVD Player/VCR
Portable DVD player won't read discs.
There are 2 errors, ho3 and ho2, I can't remember which one is which. One means the laser is going and one means it's a dirty track. I suggest you first very gently clean the lens. If that doesn't work you take apart the player and clean the whole track that the laser moves on along with everything around it (keeping in mind that the laser is fragile). If that doesn't work than I can't help anymore without seeing it.
Mar 31, 2007 | Panasonic DVD-LA95 Portable DVD Player
CODE HO3
check my response here http://www.fixya.com/support/t160505-hd03_error
Feb 20, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
Panasonic DVD-LS90 Portable DVD Player Logo
495 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
