Question about Garden
Mastercarft gas lawn mower
Mastercarft lawn mower 5hp model 11a425a515 will not start. lost manual. need to to reset timing. the pull cord jerks back when pulled.
  • 148 Answers
Take the unit outdoors. BE SAFE!
Remove the spark plug and pull the rope SLOWLY to expell any excess fuel from a possible flooded condition.
If no fuel, leave the spark plug out and check for bent blade and/or crankshaft. If bent, it is likely the flywheel key is sheared and ignition timing has been affected. If you feel the need for a manual to perform this task then perhaps this is a job for a qualified repair shop.
No offense intended what-so-ever!
If crankshaft is bent, ALL engine manufacturers recommend replacement by an Authorized Service Center.
Hope this helps.
Posted on Sep 30, 2009
Craftsman won start
Need a lot more info. Did you add oil? Did you hit anything. Take the plug out and check the spark by holding the base of the plug to the frame (metal) pulling the cord and see if the is spark. Is there a gas shutoff valve? Need the model of mower too.
Sep 01, 2014 | Garden
Why won't Lawn mower pull cord rewind ?
the springs break when jerked too hard and more than the rope lenght
Jun 28, 2014 | Poulan Pro " Pro" Self Propelled Mower
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Timeing pull cord rip out of hand when trying to start mower model 18m
what you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
Apr 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
New lawn boy mower pull cord will not pull. Worked first 2x
Did you check the oil before you ran it. They usually come dry and you have to but oil in before running. Sounds like motor might be blown.
Aug 14, 2009 | Garden
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Craftsman 5HP Mower does not start
try changing your primer bulb
May 31, 2009 | Craftsman Garden
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
