Question about Radio Communications
The radios work's great,but when i push the button to talk to the other person they can't here me....and i can't here them..whats going on???
  • putanenas May 11, 2010
    what type of radio are you talking about? Does it appear to be working otherwise?
  • 23 Answers
Sounds like a broken wire in microphone cord.
Posted on Mar 18, 2010
How do I program my radio stations on each FM band?
If we are talking a car radio, simply find the radio station and then press and HOLD the program key (1, 2, 3, etc...) you want. It should beep or blink or something to let you know it is programmed. On personal radios, sometimes the same procedure works, but often there is a program or save button on the radio you have to push first, then the button you want, then push again to save. Google your radio make/model and see if you can find it's manual online with specific instructions.
Apr 26, 2015 | Audio Players & Recorders
How to use the motorola talkabout 101
The Talkabout 101 is a very basic walkietalkie radio. With good batteries installed in the battery compartment, you should be able to turn the radio on, and simply press the front-center push-to-talk (PTT) button and speak. Release the button after speaking so the other person can do the same to talk back to you.
If you are having trouble opening the battery compartment, pull down on the black u-shaped sides and the back portion of the radio will slide down with the u-shaped sides to reveal the compartment. (This would be one of the most common questions asked on this style radio.)
Best regards.
Aug 30, 2014 | Motorola Pair Talkabout 101 2 Way Frs...
Avph3 beeps when you try to talk
there is a call button that is an option maybe you can switch off the
beep call or the info is in your manual
Jun 12, 2014 | Midland LXT345VP3 Two Way Radio
No connection the display reads "DAC FAIL CANT TALK"
In order to solve this issue, please do the following:
Unplug the power cord of the BOOM Push and maintain the button 1 on the Squeezebox player Keep maintaining 1 and plug back the power cord Release 1 when you can see RESET DAC
Fixed !
Have a great day !
J -
Aug 27, 2010 | Logitech Squeezebox Boom Radio
How do i change the channel?
Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies. Figure 16.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
One radio makes loud tone when other radio transmits
You may have a defective radio that has a bad push to talk switch which doesn't mute the receiver and feeds back audio to itself or this could be a bad solder connection or a broken wire inside.
Not much you can do except replace it or have a tech look at it.
May 11, 2009 | GE SmartHome (58173) 2-Way Radio
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Dec 16, 2008 | Motorola Walkie Talkie 2-Way Radio
Simple HOW-TO
If your radios are set identical to one another, you simple need to press the push-to-talk button (PTT) and hold it in while talking. Let go when you are not talking, in order for the other person to be able to press their PTT and talk back to you. The monitor button is only for checking to see if other users are talking on your same frequency, and if so, you are to be polite and not talk over the top of them. (So the rules say.)
Oct 09, 2008 | Audiovox Radio Communications
2-way radio
I have a model 1018 bellsouth 2-way. Are you talking about the tone that lets the other person know it's okay to talk? If so, turn the unit on---press the (fun) function button until you see the RGB abbreviation flashing. ***about three times on mine***** You should also see displayed ---ON---. Using the channel changing button---press it once. The ON should change to OFF.
Hope this helps. Have a great day.
PJ
Nov 07, 2007 | BellSouth 1040 2-Way Radio
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
