Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I'M TRYING TO FIND A COAXIAL FITTING FOR THE BACK OF THE T.V. IT'S WHERE YOU ATTACH YOUR INCOMING CABLE TO THE T.V. IT'S BROKEN OFF
  • RCA Master
  • 8,617 Answers
You can get any part needed for that model at the following link.
http://servicemanuals.vstore.ca/
Posted on Sep 30, 2009
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
SWR displays briefly then back 1.1
Your problem is not very well described, but let me guess: while you transmit, SWR peaks shortly to a high value and then drops back sharply.
There are two possible reasons:
1) Strong radio transmission pulse somewhere very close to the antenna;
2) Bad contact between connector and coaxial cable somewhere between SWR meter and antenna. Points to check:
- Coaxial connector on the cable from SWR. Is it soldered properly?
- The coaxial cable: can you see mechanical damage, stress? If you find scratches, broken isolation, sharp bends, etc, try to replace the cable.
- Connection between coaxial cable and antenna (or connector): is it soldered properly, is it not corroded or mechanically damaged?
- Connections inside the antenna (if there are any such joints): look for corrosion and mechanical damage, also loose screws.
If you find multiple places of potential problem, go step by step from antenna towards the SWR meter: if the most distant problematic location is fixed and it still shows this strange behavior, go closer.
Rarely this could be a problem in the SWR meter itself. That can be identified if you replace antenna by a dummy load. Dummy load should never cause bad SWR "flashes" (unless it is mechanically broken, too).
Mar 30, 2014 | Cobra 29 LX
Where is coaxial receptor????
Try (its a 32 inch?) using a mirror and a light but if no space you are going to have to likely remove it to connect the coax to it anyway.
Apr 16, 2012 | Televison & Video
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tuner replacement on RCA D52W20
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken coaxial
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Nov 10, 2008 | Samsung LNT4066F 40 in. LCD Television
Coaxial output broken
If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
Oct 24, 2008 | Sanyo DS20930 20" TV
Cable ready tv components
This part is called a coaxal RF connector.
Dec 01, 2007 | Televison & Video
Coaxial input jack on the TV broken off so I cannot connect my coaxial cable from wall
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Sep 18, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
