Question about Refrigerators
I have a Maytag french door/bottom freezer refridgerator. The electric in my house went out a few weeks ago. That was repaired and I was told that the neutral wire to my house had gone out. That was fixed. Now my freezer works, but the fridge does not. I HAVE replaced the evaporator fan! Help
  • 1 more comment
  • ooholly726 Sep 29, 2009
    Model # MFF2557HES
    I have a Maytag french door/bottom freezer refridgerator. The electric in my house went out a few weeks ago. That was repaired and I was told that the neutral wire to my house had gone out. That was fixed. Ever since my freezer works, but the fridge does not. I HAVE replaced the evaporator fan! Help
    Model # MFF2557HES
  • ooholly726 Sep 30, 2009
    The fan was not functioning so I ordered a new one and had it installed. Now this fan is not being told by the fridge to turn on. When the fan is out we hot wired it to make sure it was good and it ran. When it is in the freezer it is not turning on. I was wondering if there is a sensor or something that tells the fan to come on? What makes the fan turn on besides temperature? Maytag french door bottom freezer. MFF2557HES
    President:
  • 1,884 Answers
Ooholly, There is a relay that tell the fan to start when the temp rises above a preset level. May be that your relay has gone due to the elcetrical outage.
Posted on Sep 30, 2009
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
  • 15,935 Answers
Please reply with the exact model # for help with this troubleshooting.
THANKS!
Posted on Sep 29, 2009
Glacier in back of fridge wall, caused by heater going bad, is this a lemon?
If the common in your house is grounded, as it should be in the older wiring systems it should work unless the refridgerator is only grounded through the ground lug. If that is the case AND you know the house is wired correctly throughout, ie no wires switched in any switch or outlet, you can ground the common at the fridge. BEWARE! If one outlet or switch is wired backwards and you do this you will get zapped when you touch the refridgerator.
Jun 17, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
REFRIDGERATOR IS FREEZING EVERYTHING
You will need to replace the thermistor located under the control housing in the refrigerator section. Here is the part to order.
Nov 27, 2012 | Maytag MFI2569VE Bottom Freezer French...
Several days ago i replaced my water filter - i do not know if this is a coinsidence but now i hear a buzz every once in awhile like something charging - also, the water dispenser is not working and just...
There are two electric water valves which might buzz (especially if dry). One for the ice cubes. One for the water dispenser.
Since both are incorrect, they are probably not the problem. You are not getting water pressure.
It might not be the filter. Time to get wet and test. Could easily be the valve which feeds the fridge. It is probably a self piercing valve which makes a very small hole to get the water from the larger pipe. Close it all the way down (re-pierce the hole) and open it again.
Jun 03, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Jul 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
We had the same thing happen a little while back. The compressor went out and had to be replaced (it was under warranty, but the labor wasn't covered)
May 17, 2009 | Maytag MFD2560HES Bottom Freezer French...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Mar 16, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
