Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
I have a 65 pound thrust 24v minn kota maxxum and just recently it doesn't have the power like it use to... It has 1-5 speed and while on 5 speed it runs like it should on 3... Any suggestions???
SOURCE: what size battery does a minn kota 565 5 speed
12 Volt
Posted on Jul 17, 2009
  • 8 Answers
SOURCE: how does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Posted on Sep 07, 2009
  • 53 Answers
SOURCE: burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Posted on Nov 04, 2009
bigcass
  • 35 Answers
SOURCE: is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Posted on Jan 19, 2010
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota 65lb thrust 24v
Hello!
Your unit was desined to run on 24 Volts.
The control unit (electronics) will not run below 19 Volts (19 or 20, I can't remember) and the armature windings and magnets are designed for 24V as well. So, an easy answer is no your unit will not operate in 12volts.
Hope this helps out!
Mike
Sep 26, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
I lost istallation manual for minn kota power drive v2 50# thrust bow mount tolling motor, where can I find instruction manual?
Contact the people at this Email address. Minn Kota <Motors@johnsonoutdoors.com> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
How does the minn kota 65 all terrain run on 24
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
189 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
