Question about NetGear WGT624 Wireless Router
Router keeps turning of when using pc - NetGear WGT624 Wireless Router
  • chinmay_pat May 11, 2010
    Is the router getting turned off (i.e. switched off) or the connection to router from your pc is dropping.?
Freezing and crashing my wifi
you might want to open up the side panel clean your cpu fan run antivirus and spam blocker. reset your router turn off router computer and then turn on router first then computer last
Mar 02, 2014 | MSI Gt780dxr-447us
Logmein works slowly through draytek router
Check that you have the latest firmware for the router and the latest drivers for the PC. Take a look at the tech support for logmein as well.
Sep 11, 2012 | Draytek Computers & Internet
I have a acer laptop the keeps turning off wirless connection
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Aug 20, 2012 | Computers & Internet
Dlink dsm 330 keeps losing contact with pc
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Mar 03, 2012 | Computers & Internet
Wireless , internet and skype keeps dropping out, yet router libhts are on
The first thing you should try is unplugging your router. Sometimes routers get bogged down with the rules they use, so resetting the router may resolve the issue.
You may want to log into the router and discover what exactly your router is doing. If your line drops, the router may not have noticed quick enough to turn the lights off.
Jul 24, 2011 | Computers & Internet
Problem with the D-Link AirPlus DI-524 Wireless Router: Keeps timing out on wireless and wired (PC) computers. Have had to unplug wireless router and turn modem off, then plug back in and turn modem back...
Connect to router with your browser and:
Check under Tools -> Time to confirm the router is synced to either the PC clock or a time server.
Check under Advanced - Filters (and firewall) to confirm the router is always on
Check under Home -> DHCP to confirm the lease time is set correctly
Oct 09, 2010 | D-Link AirPlus G DI-524 Wireless Router...
Is there anything in a PC that can cause interference with a wireless network? Because firefox ate my earlier question, I'll keep this short: PC used to keep laptop from connecting to internet when it was...
there is nothing inside a PC that will keep it or anything else from connecting to a wireless network. You have to lookout for things that use the same frequency such as cordless phones and believe it or not microwave ovens. both broadcast at 2.4Ghz which is the same frequency wireless routers and access points use. Your problem may also be a neighbor with a wireless router or access point using the same channel. Wireless routers and access points have 11 different channels that they can broadcast on and if you and your neighbor are using the same channel there will be interference. try changing the channel on your wireless router or access point.
Apr 14, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Oct 06, 2009 | HP (319468-002) (319468002) 802.11b...
My internet keeps dropping out
possible reasons:
Dial up:
  • phone line problem.especially in wet weather,crackling on the line ,call the telco.
  • modem\router on its way out. connect directly to the modem and try it .
  • settings for idle time before disconect needs turning off, (set to 20 minute by default)in most cases.
  • if you have call waiting ,turn it off ,as it can kick you of the net when a call is trying to comes in.
if you use ADSL and/or wireless :
  • some of the above and
  • some USB dongle are prone to drop out,
  • try using a Lan cable
  • brick walls and other hard surfaces can interfere with the signal if you are away some distance from the wireless router.
  • cordless phones can cause problems, keep them away from the modem\wireless router and wireless dongle, or adapter in the pc/laptop
good luck with this and let me know how it goes
Terry
Apr 02, 2008 | Computers & Internet
Dynes Wireless G Router
Try turning everything off, PC, Router, and Modem. Then turn on the modem, then the router, then the pc. Your modem needn to connect, then the router will be assigned an ip address, then your pc will acquire an ip from the router.
Jan 14, 2008 | Computers & Internet
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
