Question about LG DLE2532W Electric Dryer
Hi, I have a DLE2532W LG Dryer, the unit runs and drys, but continues to take longer and longer to dry a load. Loads that took 45 minutes starting takeing 60 minutes and now I am up to 120 minutes. Thanks
    Problem Solver:
  • 6 Answers
This could be a problem not with your dryer but with your washer not ringing out the clothes as dry as it once did. Can you verify that in some way? Often times, though, this is more the culprit than your dryer.
Posted on Feb 28, 2010
    Problem Solver:
  • 7 Answers
    Problem Solver:
  • 10 Answers
If you cleaned your lint trap regularly then the dryer vent hose is probably clogged clean it out and that should take care of your problem
Posted on Sep 29, 2009
Dryer will heat but seems to overheat and shut off.
If that is the style with the small heater in back up top the blower wheel is probably slipping.
Dec 27, 2013 | Amana Dryers
I have an LG model DLE2532W dryer that is taking forever to dry our clothes. I have checked the continuity on the coil and it seems to be fine. I have also replaced the cycling thermostat. The heating unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | LG DLE2532W Electric Dryer
We have a LG dryer that is about 2-3 years old. The sensor is completely lit showing an obstruction but we have cleaned the vents out all the way to the roof and the sensor stays fully lit. The clothes...
Check the exhaust vent behind the dryer to make sure it's not kinked.
Take off the dryer vent and run the unit to see if it will dry normally. If it does, you still have a blockage in your exhaust vent in the wall.
Jul 20, 2011 | LG DLE2532W Electric Dryer
It takes several rounds to get our loads dry
POSSIBLE THAT THE ELEMENT THAT CONTROLS THE HEAT IS BURNT AND THAT IS WHY IT IS TAKING SO LONG TO DRY THE CLOTHES
Feb 07, 2011 | LG DLE2532W Electric Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Where do i locate the heating element on my lg dryer
no fuse unless an electronic fuse on control board, check your element continuity, then the hi-limit switch then any cycling switches for proper continuity and operation
Aug 24, 2009 | LG DLE2532W Electric Dryer
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer takes much longer to dry loads now
Hi!
You need to check the following things to sort out the issue you are facing with--
Improper sorting •Separate heavy items from lightweight items (generally, to dry a well-sorted washer load is a well-sorted dryer load).
Large loads of heavy fabrics •Large, heavy fabrics contain more moisture and take (like beach towels) longer to dry. Separate large, heavy fabrics into smaller loads to speed drying time.
Controls improperly set •Match control settings to the load you are drying.
Lint filter is full •Clean lint filter before every load.
Improper or obstructed ducting •Check installation instructions for proper ducting/venting.
•Make sure ducting is clean, free of kinks and unobstructed.
•Check to see if outside wall damper operates easily.
•Check the Installation Instructions to make sure the dryer venting is correct.
Blown fuses or tripped •Replace fuses or reset circuit breakers. Since most dryers circuit breaker use 2 fuses/breakers, make sure both are operating.
Overloading/combining loads •Do not put more than one washer load in the dryer at a time.
Underloading •If you are drying only one or two items, add a few items to ensure proper tumbling.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Thanks
Rylee
Apr 03, 2009 | GE DVLR223 Dryers
Drying cycles taking way to long
ck vent to outside starting at back of dryer looks restricted or flatten vent hose then ckd vent from wall or floor to outside to verify problem is vent issue leave vent hose off and try a load may get a little warm and dusty but would be quick way to verify
Nov 25, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
365 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
