Question about HP Pavilion dv4000 Notebook
Network issues on windows vista
Network realted issues on windows vista
network adapter jumps back to default ip address
on windows vista
and not able to identify the ipaddress whatever modem it connects to
SADSDS
Posted on Dec 20, 2007
    Problem Solver:
  • 7 Answers
Hi please tell us more about the Kind of network setup you have done. also please mention your IP address.
SmartAX MT880 driver
The SmartAX MT880 is a Router and does not require drivers to access.
Access to the Router can be done by type the I.P address of the Router in a browser e.g Internet Explore
To find the I.P address of the Router.
From a Windows PC connected to the SmartAX MT880 via a network cable,
Click the Start Menu, Click Run (On Vista and 7 you can type run in the search bar)
From with-in Run, Type cmd, Click Ok
Once the Command prompt windows appears, type Ipconfig /all with the window.
From the list of information find the line called Default Gateway (most like under Ethernet adapter Local Area Connection) a example is provide below.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.1.13
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
In this example the I.P address of the router is 192.168.1.1.
Oct 27, 2011 | Microsoft Windows Vista Ultimate Edition
I am unable to access my blitzz bwp611 router. I have tried 192.168.1.254 and 192.168.0.1 to no avail. How can I gain access to this router?
The router should be accessible from the Default Gateway IP Address of your network. Examples I have found are like this:
http://portforward.com/english/routers/port_forwarding/Blitzz/BWA611/Command_and_Conquer_Red_Alert_Counterstrike.htm
you can check you default gateway by opening a command window (Start CMD, right click CMD on the Menu for Vista/7, Start, run cmd for XP) on the command line type IPCONFIG
This will give you your IP address, Subnet Mask and Default Gateway IP address. Type the Default Gateway IP address in to you address line of the browser, you should get a sign in prompt. Unless you changed the default settings, the username and password should be left blank. That should give you access.
Jul 10, 2011 | Blitzz Technology (BWP712) 802.11g/b...
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
How do retrieve my IP ADRESS FOR MY COMPUTER & WIRELESS ROUTER
your ISP should be able to help you in that...check with the person with the internet company...
Jul 30, 2010 | Computers & Internet
My wireless adapter keeps disconnecting me from the internet, and I can't figure out how to fix it. I have to restart the computer everytime. I also can't pick up my laptop or it freezes. I have a toshiba.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this. and your laptop is freezing because you might not have got it serviced from a very long time.
Jul 14, 2009 | Toshiba (PA3212U) Wireless Adapter
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
