Question about GE Dishwashers
Door won/t lock to start washer
By pushing all the buttons am finally able to lock the door to start the washer
By pushing all the buttons the door finally locked and the washer started, thanks anyway.
Posted on Sep 30, 2009
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer will not shut off.
sounds like the final phase is not being registered on the timer or the computer chip may need to have a service tech diagnose but it isn't a complex problem just an annoying one, the final phase is a cool down cycle and also you may need to see if you have the settings for cotton clothes, the dryer will tumble them so as not to let them wrinkle. hope this helps
May 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Push start different sound water may start may not start pause
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
Mar 04, 2009 | General Electric WHDVH660H Front Load...
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
106 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
