Question about Magic Chef CGR3742 Gas Kitchen Range
Oven will not come on
The range part of the stove comes on...however the oven will not kick on
  • 2 more comments
  • Anonymous Jan 04, 2008
    The orange glow comes on, I smell gas but the oven will not come on.
  • cacey Jan 04, 2008
    The orange glow comes on, I smell gas, but the oven will not light.
  • latoniabrown Jan 05, 2009
    my range is working but not the oven
  • jameskuehl Feb 22, 2009
    The oven will not work. The "Oven On" light lights up, but there is no gas and no ignition. Broil also does not work.
    The range works fine.
  • 165 Answers
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Posted on Apr 24, 2008
Hotpoint gas stove with electric ignition, model # RGB745GEV2WH -- oven will not come on -- I played with the knobs and got it to come on once tonight but can not duplicate that. Oven will simply not turn...
That's you ignitor. They get weak. If it has a glow that is dim orange that is a sign. Another sign of a weak glowbar is you can kick the oven and make her lite off. themobilian_467.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2010 | Hotpoint RGB535 Gas Kitchen Range
I can't find my model number on my Sears Kenmore Gas stove. Several times now the stove has beeped then kicked out with EO and F2 showing in the clock area. The stove was bought in 2000 or 1999. Can you...
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
May 17, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
Flashing Lights on Thermador Oven/Range
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Jan 31, 2009 | Thermador PGR366 Gas Kitchen Range
Whirlpool sotve
Hi marywell,
Alot of times this is a sign that the voltage to the range is only half of what it should be. You may have a breaker kicked, or a bad fuse in your fuse box. When the range is only getting 110 volts instead of 220 volts, the oven will slowly heat but nothing else will work. check your breakers and I bet you will have the problem solved. Have a nice night and I hope this will FixYa. Please don't forget to rate me.
Mike
Sep 29, 2008 | Whirlpool RF367 Electric Kitchen Range
Blue blinking lights
I'm Neil
No problem
Check your Manuel
Call The Manufacturer you have a warranty!
Please rate my solution!
Jul 22, 2008 | Thermador PGR366 Gas Kitchen Range
Magic Chef CGR3742 Gas Kitchen Range Logo
250 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
