To view the Support Page, user's manual, or the service diagrams just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents like the owner's manual. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
I will assume you have checked the house's main circuit panel for any tripped brealers and tested the electrical wall outlet for a good power supply.
Hopefully the problem is just a blown main fuse inside the microwave. In order to access and check this you will have to disconnect the power cord and then remove the oven from the wall. Then remove the case in order to access the electrical parts inside.
Here is a diagram of the fuse location once you have the unit disassembled:
Just replace the fuse with an exact match and reassemble. If you tested the old fuse and it was still good, then you may be dealing with a more complicated and expensive fix possibly involving the control panel circuit board. At that point you may want to consider seeking additional assistance or just getting a new oven.
If the model number is correct, the part number is WB26X10038. You may also consider replacing the turn table shaft (coupler), part number WB06X10138.
You can purchase replacement parts at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back and let me know. I hope this helps you.
You can download GE
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Your owner's manual should cover this, but if
for some reason you don't have your owner's manual, you can download GE
Usually you just remove the two screws on the front of the top cover of the microwave (or in the grille itself) then lift up/out on the grille, as shown in the drawings below.
We're
when door is open on the edge you wil find a plastic strip .remove carefuly with flat screw driver .when removed youwill find the screws holding the handle undo screws and replace .dont 4get to replace plastic strip
