Question about Miele DG155-1 Steam Oven Single
Steam Oven DG 4664 UK/05
Once turned on it starts to alarm and a F60 fault alarm is shown on the digital screen. F60 in my manual says, the water inlet valve is not providing a tight seal. Switch the appliance off, turn off the water supply at the stop the stopcock and call the service department. This steam oven is located in a galley on a 156ft Sailing boat, so there is limited space to get in and look for the problem. What do you suggest.
SOURCE: how do I descale a Miele steam oven?
Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
Hope this helps
Posted on Feb 12, 2009
SOURCE: miele steam oven keeps wanting to be descaled after descaling!
Ours does too. Did you ever get it fixed?
Posted on Feb 21, 2010
paulc118
  • 15 Answers
SOURCE: Error code On Miele Steam oven - oO
o O means that the unit needs to be descaled. See your owners manual for the procedure. If the unit displays O - - o, the safety lock has been activated. Again, see your owner's manual.
Posted on Feb 27, 2010
paulc118
  • 15 Answers
SOURCE: Miele steam ovens
A dedicated circuit is recommended. 208-240V 20A L1 L2 & Ground, Neutral not required.
Testimonial: "Thank you excellent"
pctech1
  • 1940 Answers
SOURCE: The lock symbol is appearing
To deactivate the system lock:
  1. Press the "On" control to activate the display.
  2. Call up the SETTINGS menu.
  3. Call up the SYSTEM LOCK submenu.
  4. Select the touch control next to "Do not accept" and confirm by touching "OK".
  5. Press the "Off" control.
To activate the system lock:
  4. Select the touch control next to "Accept" and confirm by touching "OK".
Using the system lock:
  • Select the touch control next to the Unlock symbol and confirm "on". The oven cannot be operated now. The Lock symbol indicates that the lock has been activated. The timer can still be used while the lock is on. The system lock remains active even after a power cut.
  • To switch the system lock off call up the Lock symbol and confirm "off". The oven can now be used.
- Note: If the system lock is activated for more than 4 days, the oven clock will have to be reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Apr 24, 2011
How do I enter the secret Programming mode on a Miele DG 6401 steam oven to perform a total software reset?
Press and hold the timer button (the bell picture), and whilst doing that press and hold the power button. Then let go of both at the same time. Then press the timer button 5 more times, but on the fifth time hold for a few seconds. Once in Programming mode play with the options to reset and restart descaling.
Apr 12, 2018 | Miele Ovens
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Can't use my Meile pyrolitic oven fault 90
I turned it off at the main power source and then turned it on again and it worked just fine ... no further problem. I would have been mad if I had called a serviceman and had him lust throw a switch and charge the earth !
May 14, 2009 | Miele DG 4080 Stainless Steel Electric...
MIELE H 4641 PYROLYTIC OVEN
I HAVE THE SAME PROBLEM. KEEP HAVING TO TURN IT ON AND OFF TO USE IT.
Dec 26, 2008 | Miele DG 4080 Stainless Steel Electric...
Miele Microwave Oven M636 EG
Use Miele UK
http://www.miele.co.uk
click Customer Support
then
click Operating Instructions
select File;
  • M616, M626, M636
free download PDF format
May 02, 2008 | Miele DG 4080 Stainless Steel Electric...
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Ovens Logo
204 people viewed this question
Top Miele Ovens Experts
Paul Bade
John
Marvin
Marvin
Are you a Miele Oven Expert? Answer questions, earn points and help others
