Question about LG LHD65EBL Dehumidifier
Where to hook up drain hose - LG LHD65EBL Dehumidifier
  • 41 Answers
On the bucket there should be a cap. If you remove it your hose can attach to it. Run the hose top a drain. If possible, raise the dehumidifier so the water drains properly. From time to time, pour a little bit of bleach into the hose to keep mold away.
Posted on Oct 06, 2009
How do you hook up a drain hose to a Fedders dehumidifier?
Personally I would contact fedders and ask them ( their experts) that is
Oct 14, 2015 | Fedders Dehumidifiers
Where do i hook up the drain hose?
looking at the back of the machine there is a plastic female hose connection just above the top of the reservoir.
Sep 19, 2014 | LG LHD45EL Dehumidifier
Why won't it drain through the hose?
continuous drain option, So was there a plug in the end of pipe, did you remove it, does your pipe run down over, has to. Not a lot between bottom of unit and floor, But pipe has to go down over, if up and down, will not drain. down all the way
Aug 13, 2014 | Haier DE45EK DE45EK-L 45 Pints...
Direct drain
2 possibilities: #1The port that you plugged the hose onto need to be drilled so the water can come out and enter the hose. #2 The hose cannot be higher at ANY point than the bucket. Physics rules apply and the water will always fill the lowest point. Keep the hose low or raise the dehumidifier up.
Jan 06, 2014 | Danby DDR583R Dehumidifier
I hooked up a hose to drain now I am finding a puddle of water under the machine. Did I hook up the hose incorrectly?
Make sure the rubber hose o ring is in the hose connector and the hose is tightened all the way./
May 14, 2011 | LG LHD659EBL Dehumidifier
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
I have a dehumidifier in my basement and attached a garden hose to the outlet and have it draining into the sump pump drain--however it's draining into the bucket and not through the hose. And I cannot...
WHEN I BROUGHT MINE I HAVE A HOSE RUNNING TO A FLOOR DRAIN BUT REMOVE THE HOSE SEE IF THERE IS A PLASTIC COVER INSIDE WHERE THE HOSE HOOKS ON FROM THE FACTORY THE CONDENSATE PAN IS MENT TO HOLD WATER AND THIS PLASTIC PIECE HAS TO BE REMOVED FOR HOSE USE
Aug 23, 2009 | Amana Dehumidifiers
I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 20, 2009 | Maytag M7DH65B2A Dehumidifier
Need manual for fedder dehumidifer to hook up drain hose. need to know were drain hose connects.
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
Dennis
Jun 12, 2009 | Fedders A7DH45B2A Dehumidifier
Drain problem
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
Apr 03, 2007 | Maytag M7DH65B2A Dehumidifier
LG LHD65EBL Dehumidifier Logo
650 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
