Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Leak we have a leak in the front of our freezer part of the refrigerator. This leak is intermittent, about 1/4 cup when it leaks. It comes from the hindge where the wires and water supply goes into the door.
  • detwiler Dec 22, 2007
    MY LEAK HAS NOTHING TO DO WITH THE DEFROST. IT IS IN THE FRONT DOOR OF THE REF AND IS DIRECTLY RELATED TO THE WATER DISPENSER.
Hi
I have the fault with inside the freezer, so I will do as above.
Thanks for the advice
Posted on Jan 27, 2008
  • 410 Answers
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Posted on Dec 20, 2007
  • peyton thompson
    peyton thompson Dec 23, 2007
    i addressed the possibilty of a leak in the door in the second paragraph of my solution. accept my apologies for bothering you.
Msd2756de--water leaking out of the water supply at bottom of freezer hindge.i think this goes up to ice and water on door.is there an easy way to remove facing if this is the problem .
seal or plumbing has come lose.....not really a easy job....possibly the front of door has to be removed or maybe just face plate of the water disp cane removed to retighten plumbing.
Jul 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag model # MSD2754GR the refrigerator leaks
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilsh
Nov 30, 2009 | Heating & Cooling
Water accumulated under crisoer drawers and leaking onto floor.
That water is coming from your freezer during the defrost cycle. Normally there is a drain in your freezer that goes to a cup in your refrigerator and through the back of your refrigerator through a drain tube which extends down to a drip pan. If this tube gets plugged up, water will overflow in the cup and leak at the back wall of your refrigerator and through the holes that lead to the crisper's floor area. If you can remove the cup and using a wire dislodge anything blocking the drain, clean the cup of any debris and check your freezer drain for any obstruction causing water backing up and leaking !
Sep 26, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking out the front freezer door... the bottom of freezer unit has water pooled in it frozen... melts and runs out the door
The defrost drain hole in the bottom rear portion of the freezer is frozen shut. Turn off the fridge,use a hair dryer to defrost the drain hole. Pour a 1/4 cup bleach into the hole after is is cleared out. Turn the fridge back on.
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Paint chipped off of Freon lines.
Refrigerant is not a paint removing chemical . But to check , use a spray bottle with about 1/4 liquid dishwashing soap to about 1 cup of water , and spray where the paint is coming off .
Aug 06, 2009 | GALAXY Microsystems 63702 Top Freezer...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Jul 07, 2008 | Whirlpool Refrigerators
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Water leaks out of the bottom hindge part of our freezer door. It is intermittent and not a lot maby 1/4 cup.
This sounds like a problem with the defrost drain being plugged. Find that drain pan...look for the drain and clean it.
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
235 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
