Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Problem with my printer Kodak ESP 7.
I can print my pictures. I can use the scanner. I can print something on internet but I can print a document. I just change my black ink, it does not work. What do I do please??? Muryel
    Sergeant:
  • 151 Answers
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • try cleaning the printhead then print a demo page
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Posted on Sep 29, 2009
I have a Kodak ESP5210. Its an all-in-one with the printer, copier, and scanner. I can't get my scanner to work. I put a picture on it and hit "Start" and all it did was keep saying scanning. It...
Make sure any other scanners are disconnected from your computer. I had a problem with the scanner in the Kodak ESP 7 AIO printer. Kodak advised me to disconnect my other scanner. After I disconnected my Canon scanner, I was able to use the Kodak ESP 7 scanner.
MWR
Feb 28, 2011 | Kodak ESP 5 Printer
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Just purchased esp printer, does this have to be
You do not need to connect it to computer to print photos. the printer, place any document on the scanner glass and put papers in the document tray and press copy. if the printer does not work, Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.The usb cable does not comes with the printer and you need to purchase it additionally
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wireless printing
not possible... kodak all in one esp-7 and esp-9 support wireless printing. what u can do is, u can connect ur printer and computer through usb cable and then give a print command from ur computer. be it internet or any document on ur computer. kodak printer will give u high-quality prints,but ur printer does not support wireless printing.
Jul 28, 2009 | Office Equipment & Supplies
My kodak esp-3 printer is printing with a pink tint to all my pictures. can you help?
open printer access door.remove printhead and cartridges again reseat both of them.. press copy $ cancel for 5 seconds and wait for caliberation sheet to print.. or if u have connected ur desktop, open kodak home center, go 2 maintenance and click on clean printhead. now see if ur documents are printing properly. if not kodak will replace ur printhead.
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 7 doesnt scan or print properly HELP
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. KEEP ME POSTED.
Jun 11, 2009 | Kodak ESP 5 Printer
My kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 7 Stops printing at 97% done
I can understand your concerns. Just try to copy a document from the printer , by placing it on the scanner glass of the printer and by pressing Copy on the printer.if it copies,that means the printer is working absolutely fine.As far as the printing from computer is concerned,i would recommend you to
Kindly go to control panel-add or remove programs and then remove bonjour,Kodak all in one printer software and microsoft.net framework Go to start,go to run and type in "services.msc", without the quotes in the open box and press ok. restart the following services by clicking on stop the service and start the service. 1. background intelligent transfer. 2.cryptographic service. 3.windows installer. 4. remote procedure call locator. 5. printer spooler. make surethat they are set to automatic not manual.
install the latest version of Kodak software from www.kodak.com/go/downloads Your issue will be fully resolved.
Mar 30, 2009 | Kodak ESP 5 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
349 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
