Question about GE 25GT270 TV
Lost remote control - how do I control channels using TV buttons
Need to control channels to enter either channel 3, channel 4, or AUX for purposes of using modulator (to hook up DVD player) and cannot get the TV to go to those channels because it goes to pre-programmed channels automatically. Lost remote control.
  • 101 Answers
Http://www.ge.newremotecontrol.com/catalog_item.php?catnum=240961
New remote for ya:) ... dont forget to rate me plz :)
Posted on Sep 29, 2009
Everytime I press remote channel 3 keeps showing up
A television set usually receives a signal from a cable box, DVD player, etc., on a specific TV channel. Channel 3 is the most commonly used for this purpose. So when you press certain buttons on the remote, the TV tells you "Hey! Somebody selected TV Channel 3!" This is normal-- IF the remote you're using is a remote for the cable box, DVD, etc. If you get this and you don't have a cable box or other signal source, then something else is wrong... maybe you're using the wrong remote?
Mar 12, 2015 | Televison & Video
Need code for a rca coder for a ge tv
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To get the code please go to below website
http://www.rcaaccessories.com/remotefinder/
Please
Provide model of your remote
device to be programmed (VCR,TV)
Thanx
Jul 30, 2010 | RCA RCU300WBL Remote Control
I need set a universal rca control, to panasonic tv model pv-2032w
Hi! Here are the steps on hoe to program your remote control to your TV. I hope this helps.
Code List : 012,013,038,086
1. Press and "HOLD" CODE SEARCH.
2. Press and release the TV button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
3. Enter the three digit code.
4. Release CODE SEARCH.
5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Jun 28, 2010 | RCA Universal Remote Control
I have a Dynatron DYN100Z remote I need to set it for a Symphonic TV . It has worked on this TV before. I lost the code.
1. Turn your TV ON.2. Hold down "Code Search" until the red light turns on. 3. Click the (+) Channel button once each second, until the TV responds by flipping a channel. 4. One the channel changes, press the, "ENTER" button. 5. Code is saved!
Jan 07, 2010 | Televison & Video
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
I can't change the channels on the tv with remote or on tv controls. The channel up button on the tv only goes to channel 1 or aux. I need channel 73 to use satellite service. We have changed batteries in...
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Jul 03, 2009 | Emerson EWF2704 TV
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
No Aux Channel but I have the yellow and White plugs in the front!
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Apr 24, 2008 | Orion STV2763 27" TV
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
Can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Dec 15, 2007 | Toshiba 27D46 27" TV
GE 25GT270 TV Logo
222 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
