Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Why did the brushes stop rotating? - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
    Scholar:
  • 190 Answers
Please check two things:
(1) The shutoff switch on the hood is NOT set to OFF for brush speed.
(2) Remove the red filter panel from under the cleaner, behind the brushes, and clean the hair/debris from the screen filter. Squeeze the two panels together, and pull down to remove from the pocket.
Posted on Oct 03, 2009
The motor works when cover off but not when cover is on
Something must be blocking the rotation of the brushes. It has no chance to start rotation as it is immediately stopped by something.
Feb 16, 2015 | Vacuums
My Roomba brushes are not rotating!
Is the yellow plastic bearing in and turning freely - or is there hair caught around it stopping it from moving? And is the other end of the brush (with the square peg) mounted properly?
Jan 11, 2014 | iRobot Roomba 530 Robotic Vacuum
My rotating brushes have stopped rotating
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
May 07, 2012 | VAX Appliances Vacuums
THis is not a self-propelled vacuum. The problem is that the brushes are no longer rotating on their own. They only 'brush and lift carpet' when I pull backward. I have ahd the vacuum for about 1 year. ...
Sounds like you need to take the brushes off the unit and clean the end pieces that the brushes rotate around. Not uncommon that they get dirty and stop rotating. Clean all debris and add a little WD40 on the end of the bush rods that the brush spins around. Make sure the belt is on properly.
Sep 04, 2010 | Vacuums
The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
May 17, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
80 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
