Question about HP Pavilion dv6000z Notebook
Laptop starts to turn on but then shuts down, then repeats over
All lights come on, the fan starts, then hard drive revs, then everything shuts down. after a few seconds it starts up again with the same process, over and over again. any ideas or solutions.
    Guru:
  • 1,049 Answers
I think the solution might be easier then that. It sounds to me like your running on a dead battery. Make sure that your power adapter is working correctly then look at the adapter port on the laptop. Quite often people will leave the power adapter attached to the laptop and stuff it in their bag. This bends the adapter inside the back of the laptop and detaches it from the board. the result is that even though the power adapter is attached, nothing charges.
Posted on Sep 30, 2009
Do the hdd and ram reseat and update the bios from hp.com.I am sure it'll fix the issue or else run the hdd test from f10 bios
Posted on Sep 29, 2009
The hard drive indicator light of my Dell Inspiron 17 constantly flashes.
The hard drive LED is flashing because the video is data being retrieved from the hard drive. The fan runs high because the video card is working hard and creating a lot of heat. This causes the laptop to shut down.
How to fix
Get more memory.
Get a laptop cooler rest.
Get the dust and junk blown out of the inside of the laptop
Feb 28, 2014 | Dell Computers & Internet
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
Dell d600 latitude laptop not booting after using and installing vista upgrade disk. Vista o/s installed just fine, it did all the required shut downs and reboots required during the install ok and was...
the bios for the computer might not be capatibe with the os upgrade if the hard drive is removed from the laptop it might boot or the bios will have to be cleared and flashed with a new one
Nov 17, 2009 | Cars & Trucks
Hp Pavilion dv9000 turns on and off
This is likely a hard drive problem. Replace the hard drive, reinstall the operating system and your problem will be fixed.
Jun 29, 2009 | HP Pavilion dv9000t Notebook
Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Apr 24, 2009 | Dell OptiPlex GX620 PC Desktop
New Board; Fan turns on; No Screen; Cap, Scroll, Num lights flash
Great!
I've been bitten by that, especially on Dell laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 05, 2009 | Dell Inspiron 1000 Notebook
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Acer quit working
Well, the 1st thing to check is boot into safe mode (F8 at boot) and see if you can get to the desktop.
If you can, run system restore and then see if you can boot to normal mode.
If it shuts down, boot to the system BIOS, and see if the system will continue to run, if it does, then your issue is most likely a operating system problem or a hard drive problem causing an OS problem.
If the system doesn't shut down in BIOS, next is try to boot to a CD. You may have to remove the Hard Drive to exclude it from the issue. If the system boots to a CD and will continue to run, then we are pretty sure the HDD/OS is the issue.
Next would be trying to run diagnostics on the hard drive, if they fail, replace the drive. If they pass, reinstall WIndows.
Jul 11, 2008 | Acer Aspire 5315 Notebook
HP Pavilion dv6000z Notebook Logo
233 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
