Question about Samsung LN46A650 46 in. LCD HDTV
Samsung LN46A650 flickering issue on HD channels
I have a flickering/flashing issue that seems to only appear on HD channels. It can be very prevalent at times but is usually only an occaisional issue, flickering once every several minutes or so. Could it be the cable wiring or the DVR box or something else? What is the best way to narrow down exactly what the cause is?
thecritter
  • 29 Answers
SOURCE: Samsung TV flickering image
You seem to have what is called error diffusion. Either call samsung about it and arange service or do it on samsung.com. What kind of warranty do you have? Depending on your date of purchase you might be able to get samsung to help cover it or pay for it all.
Posted on Mar 09, 2008
Agent Dort
  • 216 Answers
SOURCE: Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Posted on Jul 15, 2008
SOURCE: 3 horizontal lines on Samsung LN46A650 upon start
I had the power board capacitors on my Samsung 46LNA650 checked, and the out-of spec/leaking ones (13 in all) replaced. The horizontal lines disappeared; but, the left side of the panel was dark for about 20 minutes (until warmed-up). I then found this forum/link that solved the problem! This simple fix was probably all that was ever needed - IT WORKS!!!!!!
http://forums.cnet.com/7723-13973_102-391250.html
My Samsung now has a perfect picture again.
Posted on Dec 05, 2010
  • 718 Answers
SOURCE: Can't get HD cable channels on Samsung TV
Have you check with the cable company to make sure they are broadcasting to you in HD ?
It takes more bandwith so some cable companies will charge extra for it so you will have to check.
Posted on Feb 06, 2011
Samsung tv has flickering lineswhile watching tv
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec How to Fix Samsung TV Flickering Blinks Flashing Flat Screen ... Rating is available when the video has been rented. ... sorry to bother you tampatec but i have a RCA tv it works great when it's.... My Toshiba Full HD led tv model 32PT200ZE is having issues of screen blinking/flashing and horizontal lines.
Sep 25, 2015 | Samsung Televison & Video
Samsung LE40R71B flickering problem
appears other people are having the same issue with Samsung TV's.
Try calling Samsung or wherever you bought it from.
I've been dealing with Samsung on this issue.
We got a 40" LCD in October 2010 and it started flickering January 2012.
Changing it from 'standard' to 'movie' helped (natural and dynamic flicker)
Then it started flickering in 'movie.'
I called Samsung and told them this issue is all over the internet. They agreed to pay for repair, parts and labor, even though it's out of warranty.
The guy just left and this is what I know. He said that in the 46" and larger, the issue is a jumper. In the 40" and, I think, smaller, it's the panel. He's ordering the panel and will be back to replace it when it comes in from the warehouse in CA.
Try calling Samsung and good luck!
Dec 28, 2013 | Samsung LE40R71B 40 in. HD-Ready LCD...
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Picture issues
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Mar 09, 2008 | Samsung SP-S4243 Television
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung LN46A650 46 in. LCD HDTV Logo
362 people viewed this question
Jerry Greenberg
Jerry Greenberg
