Question about Toshiba Computers & Internet
Where i can buy toshiba satellite p10-304 display screen inverter
    President:
  • 2,600 Answers
I generally use Ebay for most of these purchases, mainly because the purchase is protected through Paypal and the selection is huge...you are not confined generally to one supplier, so everyone bargains.
Posted on Sep 29, 2009
  • Toshiba Master
  • 4,806 Answers
You will be able to purchase an inverter board here>>>>>>>
http://www.impactcomputers.com/k000009570.html
Take a look at the back of the inverter for a copper coil, if youre-solder the solder points around the coil you may find it works againas components that suffer from extreme heat the solder joints drycausing bad connections, re-floating the solder solves the problem in90% of cases.
If you don't know how to remove the inverter from the bottom of the screen then please post back.
Regards.
How do you do a toshiba satellite PSC16U-032031 display backlight replacement
you will need to take out the screen todo any work on the display.
you will find the inverter and the bottom of the screen.
Jun 05, 2014 | Toshiba Satellite C655D-S5087 NoteBook AMD...
Toshiba satellite M305 S4907 comes on but monitor is blacked out can barley see
http://www.screentekinc.com/Toshiba__Satellite__M305-series-laptops-lcd-screens.shtml
The Toshiba Satellite M305-S4907 Notebook PC, uses a single CCFL for a Backlight.
Primer before we go on;
An LCD screen cannot produce light. It needs an additional light source,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor image.
The additional light source is a Backlight.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
A screen Inverter is used on laptops that use CCFL for Backlighting.
A screen Inverter converts the power (Electricity), from the laptop, for the LCD screen, and Backlight.
Laptops that use a series of LED's for backlighting, do Not use a screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
http://www.sparepartswarehouse.com/Toshiba,Satellite,M305-S4907,PSMD8U-02R015B,Laptop,Inverters.aspx
The plastic thin frame in front of the LCD screen, is the Display Bezel. (Toshiba = LCD Bezel)
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen.
(LCD Screen Frame, actually)
Easy to get to; easy to replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
How to test a screen Inverter? Requires a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Because of this; and the low cost, plus ease of replacing; most home users just opt to replace it.
Know this;
Fluorescent lamps have MERCURY inside. HIGHLY poisonous.
Now couple that with the long thin makeup of the CCFL, and how easy it is to break it.
This is why if the screen Inverter is found to NOT be the problem; I would suggest replacing the LCD screen itself; instead of trying to replace the CCFL, and cause possible Mercury poisoning.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 12, 2012 | Toshiba Satellite Computers & Internet
Toshiba Satellite P105-S9722 white screen on stat up
Don't assume. Diagnose.
Problem could be graphics chipset, Video Cable, screen Inverter, or LCD screen.
Graphics chipset:
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
(Back of laptop - Blue)
Example of a VGA Cable, and a VGA connector, (Port on laptop),
http://en.wikipedia.org/wiki/VGA_connector
If you have a CRT type of monitor (Looks like a small TV), you can use it, or a flat LCD screen monitor with a VGA cable.
The Toshiba Satellite P105-S9722 Notebook PC, also has a DVI connector on the back of the laptop. (Next to the blue VGA port)
You can connect a flat LCD screen monitor with a DVI cable.
Example of a DVI Cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default the display should be on the external monitor.
If not;
Press, and hold down on the Fn key, (Bottom left), and tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
You will see a list. It 'hot cycles' through the list, until you come to the external monitor device you are using.
http://shop.mcccomputers.com/network-modem-cards/6037-toshiba-satellite-p100-p105-p105-s6104-p105-s9722-video-board-256mb-ts15082.html
External monitor display shows no white screen?
Your graphics chipset is good.
Go on with the diagnoses.
Problem is with the Video Cable, or in the Display Assembly.
(Screen Inverter or LCD screen)
Video Cable:
The Video Cable attaches to the motherboard under the Switch Cover, and about at the F2 and F3 keys.
It then routes under the left Hinge, and up into the Display Assembly.
From there it connects to the screen Inverter, and back of LCD screen,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/big/toshiba-satellite-p105-11.jpg
From;
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Due to normal opening, and closing of the laptop, the Video Cable may become pinched, and pulled on.
This can lead to a simple loose connection of the Video Cable TO the motherboard, or TO the back of the LCD screen.
(The screen Inverter connection should also be checked)
Visual inspection will NOT do. You need to physically see if you can plug the motherboard connection, and LCD screen connection in.
It could be just loose enough you won't be able to see it, but will affect the display.
Sheath of Video Cable needs to be visually inspected for signs of damage. Signs of damage to the sheath, may also mean damage to the tiny wires inside the sheath of the Video Cable.
(Stretched/Broken)
Assurance that the Video Cable is not the problem, means checking out, or have checked out, with a multimeter set to OHM's, to run a continuity check of all the wires.
('Mom and Pop' computer store. See if they will check it)
Or simply replace the Video Cable. (After you fire up the laptop, and see if loose connections was, or was not the problem)
http://www.batterysupport.com/toshiba-satellite-p105-s9722-cable-p-377633.html
(Left side connects to LCD screen. Right/Top connector goes to motherboard. Right/Bottom connector goes to screen Inverter)
Video Cable checks out OK?
Go on to screen Inverter.
http://www.ebay.com/itm/TOSHIBA-Satellite-P105-S9722-laptop-lcd-Screen-Inverter-/250759700669
The screen Inverter is behind the Display Bezel, and mounted at a location towards the bottom of the LCD screen frame.
A screen Inverter is tested with a sensitive multimeter. Read fairly expensive,
It is for this reason that those who do not have access to a sensitive multimeter, usually just replace the screen Inverter.
(Also low cost, and ease of access to replace)
Screen Inverter checks out OK?
Problem is the LCD screen,
http://www.amazon.com/SATELLITE-P105-S6084-P105-S9722-P200-140-REPLACEMENT/dp/B007QEEYGE
Regards,
joecoolvette
[ Bet it's the video cable, or screen Inverter, that is the problem ]
[ Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
The Toshiba Satellite P105-S9722 Notebook PC, uses One CCFL for a Backlight.
Average length is almost as long, as the LCD screen is in height,
General example,
A CCFL contains -> Mercury, just like Fluorescent lighting used in homes, and businesses.
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
90 Percent of the Time the fault is a bad screen Inverter.
Primer over.
Oct 16, 2012 | Toshiba Satellite P105-S9722 Notebook
Are the display bands compatible?
1) Toshiba Satellite P300-13j LCD screen example,
http://www.screentekinc.com/Toshiba_Satellite_P300D-13J--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and uses one CCFL for a Backlight.
2) http://www.lcds4less.com/ToshibaLaptop__Toshiba_Satellite_P300D-12L__laptop-screens.html
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and has 1 CCFL for a Backlight.
There is a pretty good chance. The screen Inverter and LCD screen are a matched unit. I would remove the screen Inverter from the P300-12L, and use it also.
Looks like this,
http://www.lcd-inverter-shop.com/Toshiba/Toshiba-Satellite-P300D.html
If I may ask;
1) Is there obvious damage to the LCD screen?
2) If there is not obvious damage to the LCD screen, have you used an external VGA monitor with the laptop?
To see if the problem is the graphics chipset, or the video cable, or inside the Display Assembly.
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P305/take-apart-notebook-1.htm
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Post back in a Comment.
Regards,
joecoolvette
[Primer:
An LCD screen cannot produce light by itself,
(Click on the monitor icon,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/ )
It needs an additional light source. A Backlight is the additional light source.
LED stands for Light Emitting Diode
CCFL stands for Cold Cathode Fluorescent Lamp.
Observe the last 8 photos especially. This article shows you that the LCD screen is an assembly. It is composed of layers. Just like the 3M company's tutorial. Also shows general instructions for replacing a Backlight.
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
It is a small circuit board, and is usually mounted towards the bottom of the LCD screen, and behind the Display Bezel.
A CCFL, (Or two of them), uses a screen Inverter.
LED backlighting however, may or may not use a screen Inverter.
Using LED's for backlighting is relatively new, when discussing backlighting technology.
Some of the first designs of LED backlighting does use a screen Inverter.
Newer designs do not seem to.
90 PERCENT OF THE TIME the problem can be attributed to a bad screen Inverter.
Aug 21, 2012 | Toshiba Satellite Computers & Internet
My toshiba L35-S2161 the monitor only displays lines in colors, what to do to fix it
Since you diagnosed by using an external VGA monitor, you now know the fault lies in either the Video Cable, or the Display Assembly.
(Also known as GPU. Graphics Processing Unit )
A) Video Cable:
(Toshiba = LCD FL Cable )
See if the connections are good. Check the motherboard side connection of the Video Cable, AND the LCD screen side connection.
A loose connection can do this.
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/taking-apart-laptop-1.htm
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/remove-notebook-screen.htm
(On both links above you can click on the photos to enlarge )
Observe the sheath of the Video Cable for obvious signs of damage.
If the cable looks pinched, stretched, or torn, the tiny wires inside the cable may be damaged also.
Best method is to remove the Video Cable, and perform a continuity test of the wires inside the cable, with a multimeter.
(An economical unit can be purchased for around $8 to $12.
Analog or digital is fine )
B) Display Assembly:
Video Cable checks out OK;
1) Check the connections to the screen Inverter board.
Make sure they are tight. Make sure the Inverter board does not appear to be damaged.
2) Screen Inverter board:
Primer;
An LCD screen does not produce light. It needs an additional light source.
http://en.wikipedia.org/wiki/LCD_screen
A Backlight is usually a CCFL, or a series of LED lights.
The Toshiba Satellite L35-S2161 Notebook PC, uses a CCFL for a Backlight. (Uses 1 CCFL)
(Average size is 2mm Thick, and is close to the width of the LCD screen in question, Long )
A screen Inverter converts the power (Electricity) from the laptop, for the Backlight and LCD screen.
It is located behind the Display Mask, (Display Bezel), and mounted towards the bottom of the LCD screen.
http://www.zkarlo.com/selected-zkarlo-part/inverter-board-p2215.php
A bad screen Inverter usually causes a garbled display, or doesn't light the Backlight up.
To test a screen Inverter you need a sensitive multimeter, or use a spare Backlight bulb that is known to be good.
Bulb lights up the Inverter is good, the Backlight in the LCD screen assembly, is bad.
[ The LCD screen is composed of layers. These layers are held in place by a metal Screen Frame. {Resembles a picture frame }
The Screen Frame comes apart.
Screws are removed, and the Screen Frame comes apart in four pieces, (Four sides), or the Screen Frame comes apart in two pieces as an Upper half, and Lower half.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/big/satellite-L35-screen-08.jpg
The Backlight bulb is taped to one side of the LCD screen layers, and is under that side of the Screen Frame.
The LCD screen layers MUST be kept aligned, as they were from the factory. For this reason alone, it is tedious for an experienced technician, and is usually not done at the consumer, or DIY level.
http://www.zkarlo.com/selected-zkarlo-part/lcd-cable-p2216.php
More in a Comment.
Regards,
joecoolvette
Feb 05, 2012 | Computers & Internet
Screen on laptop is distorted halfway
A) Video Cable connections are loose:
Connection at the motherboard, and the connection at the back of the LCD screen, in the Display Assembly.
Both need to be checked.
[For Toshiba the Video Cable is termed LVDS Cable.
Low-Voltage Differential Signaling Cable. I will just keep referring to it as the Video Cable ]
B) Video Cable is damaged:
Observe the sheath at the motherboard side of the Video Cable?
Is there obvious signs of damage to the sheath of the cable?
If so, there may also be damage to the tiny, thin wires inside the sheath, of the Video Cable.
Due to the routing of the Video Cable under the left Hinge, the Video Cable may be pulled on. This can create a bad connection.
Due to the above also, the Video Cable's sheath may be damaged, and the wires inside.
A view of the Video Cable by itself,
http://www.batterystyle.com/toshiba-satellite-a205-s5880-cable-p-484063.html
If the Video Cable checks out to be OK, the next item is the screen Inverter.
To test a screen Inverter you need a sensitive multimeter. This usually means expensive. { Or use a known to be good, compatible screen Inverter } Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter. {Or LCD screen)
Most consumers decide to just replace the screen Inverter because;
1) If the problem isn't the screen Inverter, it is the LCD screen.
(A LOT of people buy an LCD screen, when all they really needed was a screen Inverter)
An EXPENSIVE part.
(LCD screen? $150 to $400 approximately. Screen Inverter? Usually around $22 to $48 )
2) The ease of access to replace.
As stated, if the problem isn't the screen Inverter, then it is the LCD screen.
1) With ALL power removed, AC adapter (Charger), and Battery, remove the Keyboard Bezel, and the Keyboard.
This is the motherboard connection side.
Display Assembly removed with Video Cable.
Now remove the Display Bezel, and LCD screen assembly, to access the Video Cable connection to the back of the LCD screen.
{NOTE*
The screen Inverter is mounted at the bottom of the LCD screen, and behind the Display Bezel }
This shows the Video Cable, and it's connection at the motherboard side,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-2.htm
Scroll down, click on the photo in Step 9.
The Video Cable is the cable to the upper Left side. Has one Red arrow pointing to the left.
The photo in Step 10 shows the Video Cable disconnected from the motherboard.
(This is Page 2 of a disassembly guide. Pages 1 through 4 are available above, and below. Page1::Page2::Page3::Page4::Find another model,
in white.
Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter, or LCD screen) )
2) LCD screen side:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-4.htm
http://www.insidemylaptop.com/remove-lcd-screen-from-toshiba-laptop/
All three links above will help you with checking the connections, or removing the cable to perform a continuity check. (Test)
Also with accessing the screen Inverter, and LCD screen.
Regards,
joecoolvette
Jan 25, 2012 | Toshiba Satellite A205-S5880 Notebook
Toshiba satellite monitor is scrambled, how to fix?
Check to see if the problem is the screen Inverter, or the graphics chipset, or the LCD screen.
Use an external monitor as a test.
If the screen of the external monitor shows a scrambled display you have a problem with the graphics chipset.
If the screen of the external monitor does Not show a scrambled display, you have a problem with the screen Inverter, or the LCD screen.
90 PERCENT of the time the fault is the screen Inverter.
External Monitor;
1) You can use a CRT monitor, (Looks like a small TV), as a VGA monitor,
Or
2) You can use a flat LCD screen monitor that has a VGA cable.
A) Laptop OFF, and monitor OFF, attach the VGA cable from the External monitor, to the VGA port on the Toshiba Satellite A205 series Notebook PC.
This is an example of a VGA cable, and it's connector, and a VGA connector on the laptop,
B) Turn the monitor on. If it is a CRT style let it 'warm up'.
Turn the laptop on.
C) The display is supposed to automatically show up on the external monitor.
If it does not, press, and hold down on the Fn key, and also press the F5 key.
Still no?
Holding the Fn key down, tap the F5 key again.
Display good on external monitor? Problem lies with the screen Inverter, or the LCD screen.
Either OR.
Primer:
A Backlight is a CCFL.
An Inverter (screen Inverter) is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
As previously stated, 90 PERCENT of the time the fault is the Inverter.
Laptop open looking at the display assembly, the plastic thin frame in front of the LCD screen, and surrounds the LCD screen, is the Display Bezel. (Resembles a picture frame)
The Display Bezel is removed to access the screen Inverter.
The Inverter is right behind the Display Bezel, and located at the bottom area of the LCD screen.
The Display Assembly has to be removed from the laptop, to remove the Display Bezel.
Toshiba's term for the Display Bezel is Display Mask.
The Toshiba Satellite A205-S5804 Notebook PC is one of the Satellite A205 series of Notebook PC's.
This is a link to a free Service Manual for a the Satellite A205 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the second Satellite heading. The one that begins with Satellite A10.
Scroll across, and click on A200.
After you click on A200 it may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 146.
4.10 Display Assembly
Page 151 shows how to remove the Display Mask.
4.11 Display Mask
Page 153 deals with the screen Inverter.
4.12 FL Inverter Board
Takes a really sensitive (Read fairly expensive) multimeter to test an Inverter.
Due to the low price, and ease of replacing, the screen Inverter is replaced to test whether the old one is bad.
Example of a screen Inverter (FL Inverter Board) for a Satellite A205-S5804 Notebook PC,
http://www.batterysupport.com/toshiba-satellite-a205-s5804-inverter-p-216526.html
Compare to the price of a replacement LCD screen,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A205-S5804/
To summarize so far;
1) Display shows good on external monitor. Replace screen Inverter. Still the same problem? Replace the LCD screen.
2) Display on external monitor is scrambled also?
Fault lies with the graphics chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The GPU for a Toshiba Satellite A205-S5804 Notebook PC (Part Number PSAF3U-0NR00V), is an Intel (Mobile) GL960 Express,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
It is soldered directly to the motherboard, therefore it is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics.
ON the motherBOARD.
The GPU is soldered to the motherboard.
In comparison if the GPU were soldered to a removable adapter card, it would be a graphics card, and Not integrated graphics }
This means if the graphics chipset is found to be bad, motherboard replacement is the solution.
{ Disassembly guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm }
Regards,
joecoolvette
Nov 05, 2011 | Toshiba Satellite A205-S5804 Notebook
Toshiba satellite a300 laptop display problem screen black, no display at all.
You laptop either needs a new Cable from the Motherboard to the Screen, a new power inverter, or a new screen. Most commonly, I have seen the video cable get smashed between the hinges/plastic case, and this causes the wires to break apart, leading to a black screen.
Here is the power inverter for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,Inverters.aspx
Here is the video cable for your laptop: http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3392&zenid=7903c7a1a62c4c2cbfef6ea30865373c
Here is the LCD screen for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,LCDs-Displays.aspx
If the display comes back, slightly, when you lift the display lid up and down, this would be a sign that your cable is bad. If you get no reaction from opening and closing the lid, you may have a bad inverter or screen. It is most commonly the inverter or the cable.
If you have a spare monitor, you could plug it into the VGA connector on your Laptop as a temporary solution. If after plugging the monitor in, you get no display, try pressing Fn + F5.
Mar 09, 2011 | Toshiba Satellite A300-0CF035 Notebook
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
My screen fails to illuminate, I can make out text just barely but there's no light - I think it's the inverter? If so I found one to buy but I'm looking to at least see it in my laptop first, is it...
  • Hi, hope this will help you with your problem. There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Select, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "Restart "Computer." *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Feb 02, 2010 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
224 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
