Question about Kenmore Grilling
Can't open valve on gas grill propane tank
This is the second time this has happened. The last time it happened, the tank was almost empty. We tried every kind of tool to turn it, but no luck. We just replaced the tank, and it worked when we first hooked it up. The second time we went to use the grill, the valve wouldn't turn, as if it had been turned too tightly. I'm a girl with not much man power, so I don't think that it's been turned off too tightly. Can you help??
I think she is talking about not being able to turn the valve on the propane tank...like its frozen. And it just happened to me as we'll.
Posted on Jul 08, 2013
4 Suggested Answers
radar001
  • 1051 Answers
SOURCE: Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
Posted on May 19, 2010
  • 464 Answers
SOURCE: Grill does noty get hot
try opening the tank very slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Posted on Oct 14, 2009
garing
  • 998 Answers
SOURCE: Very little gas getting to burners
when you first turn tank on let it sit3-4 minutes to let the regulator adjust it's self befor you open a valve
Posted on Aug 24, 2009
The grill is too slow when grilling. It doesn't seem to get hot enough
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Aug 01, 2014 | The Holland Grill HGG421408LP Epic Gas...
Gas grill no flow of gas
Jul 14, 2014 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Need to know how to reset the LP Gas flow for a Webber 300 BBQ
If you just installed a new, full tank of propane and turned it on and the burners wouldn't light.
Turn the tank off, disconnect from the grill hose (you'l hear a whooshing sound and smell gas, but that's alright). Wait several minutes and reconnect the hose to the tank. Turn the gas valve on very very slowly, until it's full open. Now, try lighting your grill.
Remember, you will need to turn the tank valve on very very slowly every time you change tanks or turn the tank off after grilling.
What happened was this ... When you turned the tank on quickly it locked up the grill's gas regulator. Doing what suggested usually solves the problem. Oh, one other thing ... be sure your tank is not empty. The grill you have uses a lot of gas.
Feb 02, 2011 | Weber Grilling
I cannot get the gas grill to light. The tank was not completely empty but I replaced it anyway to make sure that was not the problem. I have the same problem with the refill. It does not seem to be...
the regulator could have gone into lock up.
try this to unlock it...
  1. Open the BBQ Lid
  2. Turn ALL main control knobs to the "OFF"/CLOSED position
  3. Turn the Propane tank valve to the "OFF"/CLOSED position
  4. Disconnect the Regulator hose from the Propane tank
  5. Turn ALL main control knobs to the "ON"/OPEN position
  6. Let stand for 1-2 minutes, allowing all excess gas in valves and manifold to dissipate
  7. Turn ALL control knob back to the "OFF"/CLOSED position
  8. Reconnect the regulator hose to the Propane tank- hand tighten only.
  9. Check all hose connections to ensure that a positive seal has been made
  10. SLOWLY turn "ON"/OPEN the propane gas supply
  11. Wait approximately 5 seconds for the regulator pressure to stabilize
  12. Turn "ON"/OPEN the selected burner control knob to "HI"
  13. Press the Multi Spark ignition button or match light selected burner.
  14. Hope this helps you has me in the past!
Jan 08, 2018 | Char-Broil 463220004 Grill
Gas Not Flowing
Try this. Turn tank off, open all three burners for a minute or 2. Close burners. Open tank very slowly. Open primary burner, (usually the front burner) and try to relight. Should work, but if not check that valve is secured to tank and check for leaks with soapy water.
May 02, 2010 | Weber Genesis Gold B Premium Grill
Flame not staying lit
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 28, 2010 | Thermos Grill2Go Gas Grill 4656110
My weber gas grill suddenly does not heat up enough. It has been working for two years and suddenly the amount of flame is tooooooo small to cook.
Hello. You may not have enough propane left in the tank for it to work properly, you may not have turned the tank valve to the full open position, or your valve safety device may have kicked in. IF this last item is what happened read on:
To reset the check valve and get back to cooking on your gas barbecue grill, first
  • turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank.
  • Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders.
  • Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released.
  • Leave the grill, side burner, rotisserie, etc on high for a few minutes with the hood open before turning all the valves back to the off position.
  • Make sure. Most gas barbeque grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the “on” position.
  • With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
  • Slowly. The trick here is to turn the hand wheel slowly.
When the propane gas tank is new or newly-filled, the gas is full and the OPD is pushing slightly on the top filled area and the gas will want to burst through the valve. Slow it down by turning the valve on slowly and the check valve will reset itself.
Regards, Joe PS please rate my answer. Thank you.
Jan 16, 2010 | Grilling
Grill won't start
The regulator on the gas feed line is not working properly. Take the regulator to a propane supplier and have the regulator checked.
Apr 25, 2009 | Grilling
Jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Jan 21, 2008 | Grilling
Grilling Logo
1,836 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
