Question about Sharp SF 2020 Copier
Sharp copier SF-2025 displays an error code U%.
Sharp copier SF-2025 displays an error code U5. Can eliminate by powering down copier and powering it back up again.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Posted on Oct 01, 2009
  • Sharp Expert
  • 255 Answers
U5 means the ADF (Automatic Document Feeder) is not sensed. Connect its cable behind the copier if no ADF present, disable by pressing C,Interrupt, O, Interrupt - display will go off. Press 26 press print press 1 print. Press 00 and press print. You have disabled the option then press CA.
Posted on Dec 01, 2009
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
How to check the meter
just push the 0 key or cancel key, just try you can read the counter
Jun 24, 2013 | Sharp SF-2025/2030 Copier Toner Black...
Code error H2
h2 means the open the termistor.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 03, 2012 | Sharp SF-2025/2030 Copier Toner Black...
H5 Code appears and shuts down my Sharp SF 2025 copier
Hello sir; To reset H5 code ,turn power on and open front door , press and hold exposure key while closing front door.
Jan 17, 2010 | Office Equipment & Supplies
Sharp copier SF-2025 displays an error code H4
H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
Nov 03, 2009 | Sharp SF 2020 Copier
AE Code on Sharp SF2025, What means?
exposure lamp or exposure fuse
Jun 08, 2009 | Sharp SF 2020 Copier
On a sharp SF-2020.. I get a U5 code with 01 subcode...
u5 indicates the ADF can't communicate, make sure the ADF is pluged into the copier. MAKE SURE TO UNPLUG COPIER BEFORE CKECKING ADF PLUG. If all is good then main board is bad.
Feb 25, 2009 | Sharp SF 2020 Copier
LightBulb in SF 2025 not working
Yes, replace exp. termal fuse,
esr
Nov 12, 2008 | Sharp SF 2020 Copier
Sharp Copier 2025 error steady CH
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
Jul 24, 2008 | Sharp SF 2020 Copier
422 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
