Question about Plumbing
I have a schematic symbol for what looks like a relief valve but the triangles are striped?what type of valve is it ?
    Problem Solver:
  • 16 Answers
The striping usually means there is an electrical charge present there.
Posted on Oct 12, 2009
Schematic?
A schematic, or schematic diagram, is a representation of the elements of a system using abstract, graphic symbols rather than realistic pictures. A schematic usually omits all details that are not relevant to the information the schematic is intended to convey, and may add unrealistic elements that aid comprehension. For example, a subway map intended for riders may represent a subway station with a dot; the dot doesn't resemble the actual station at all but gives the viewer information without unnecessary visual clutter. A schematic diagram of a chemical process uses symbols to represent the vessels, piping, valves, pumps, and other equipment of the system, emphasizing their interconnection paths and suppressing physical details. In an electronic circuit diagram, the layout of the symbols may not resemble the layout in the circuit. In the schematic diagram, the symbolic elements are arranged to be more easily interpreted by the viewer.
Schematics and other types of diagrams, e.g.,
Transit map, a schematic map (i.e. not drawn to scale, stations are equidistant, lines are drawn at 45 and 90-degree angles)
Schematic of a drive train
Chemical engineering schematic
exploded view of a 3D-engineering drawing
Jan 22, 2016 | Computers & Internet
How do I type in symbols that don't exist on my key board, in so can I send you a picture to identify gun SN?
If the following line works, it should appear as a triangle/upside down pyramid
<p>&#8711</p>
The link to instructions is here:
HTML Symbol Entities Reference
Sep 23, 2014 | Military Collectibles Mannlicher Military...
How to find and change a fuse
Look around the area where the plug from the wall is connected to the power board, the fuse is usually in the same general area. It may be hard to identify if its not a regular type fuse. If its an electronic fuse its will be marked with a little schematic symbol near it. Look up electronic schematic symbols for fuses to find what it will look like.
Aug 10, 2014 | RCA Televison & Video
Leaking relief valve on solar panel
I had to replace mine a few years ago. Just look on line. Search for pressure relief valve, or add solar. You will get a lot of responses. Comparison shop and buy. On line auctions work well also.
Mar 07, 2014 | Caleffi Solar Collectors
Hydraulic schematics
Sorry but it will be the cylinder. The oil is leaking around the worn seals on the ram or past score marks on the cylinder bore. It goes up because the pump generates more flow than the leak. It the relief valve was faulty it would not go up but by pass back to the tank.
Jun 10, 2013 | Welding Tools
Pressure relief valve blows at 80 psi. On a 150 psi valve
I had a problem with the relief valve on my compressor, too. I replaced it with the same value relief valve for short money (under $10) and was done. I suggest doing the same thing to yours.
Feb 19, 2013 | Air Tools & Compressors
How do you set the clock and get it to stay on
press the clock button to set the time. Press the "up" button which looks like a triangle symbol or the "down" button whih looks like a triangle upside down symbol until the correct time is on the display , then hold in the clock button for 5 seconds for the time to be displayed.
Apr 15, 2010 | Whirlpool RBS275PD Electric Single Oven
Where is the power steering container located.
The power steering pump is a CB-series, vane-type positive displacement pump with an integral fluid reservoir. A pressure relief valve limits maximum system pressure, and is located inside the flow control valve in the pump housing; the relief valve is not serviced separately. The power steering pump is driven by the engine via an automatically tensioned drive belt.
Just Fallow the Belt and Look for the ONLY Component that Has A Cap on it
PLEASE DONT FORGET TO RATE ME
Jan 21, 2009 | 1998 Buick LeSabre
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Plumbing Logo
137 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
