Question about Panasonic DMR-EZ37VS
Vhs tape stuck in unit how do I remove - Panasonic DMR-EZ37VS
I have opened my vcr before and removed a tape. The repair shop charges $79 bucks and I could buy a new one for that so I figured what the heck. Unscrew and carefully remove the tape and screw back together. I have done this numerous times and it's worked fine.
Posted on Sep 29, 2009
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Small motorla color tv vhs tape is stuck in tv
Remove power to the set - unplug the wall outlet. Remove the screws that attach the back cover. Remove the cover. Remove the cables that connect to the VHS drive to the TV main board. Remove the mounting screws that attaches the VHS drive to the set. Remove the VHS drive. Manually turn the take-up gear which is near a motor to allow the tape to mechanically eject the tape - do not force.
Feb 19, 2011 | Televison & Video
A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Jun 01, 2010 | Televison & Video
Vhs tape stuck in unit, unit won't recognize that a tape is inside
This is what i did with mine i removed the lid and had to give it a little push and the video would eject although mine reconized the video when it was in.
Feb 02, 2010 | Televison & Video
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
Apr 27, 2009 | Sony SLV-D300P DVD Player/VCR
Vhs stuck - plastic roller part floting inside case.
You could probably do it yourself, but it would be best if you got professional help, you know, just in case if you don't know where the part went.
Oct 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
VHS Tape stuck and won't eject
you going to have to open it up and remove the tape manually, either the belt drive is broken or gears are.
you going to have to get your hands dirty. :)
Jun 25, 2008 | RCA DRC8335
Can't put a VHS in
If the VHS isnt going in it may require a little force as the track might have gotten stuck with dust. if you think its something else i suggest you openj it up and see if these is anything logged in the carriage way or if the tray might just be stuck. once it is open simply insertthe vhs tape and keep pressing in on it until the machine takes it in. while pressing keep you eye on the carriage and see hwat might be stuck as to preven the tape from entering. BUT I THINK IT MIGHT JUST REQUIRE A LITTLE FORCE as it may be binded with lack of use
Jan 04, 2008 | Televison & Video
Panasonic DMR-EZ37VS Logo
153 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
