Question about HP LaserJet P3005n Printer
HP LJ3005n printer is making loud grinding noises from the fuser to the output roller assemblies, but only when the output roller is engaged. The fuser works fine. I tore apart the printer looking for something wrong, other than a loose gear on the swing arm, which is now tight, I can see nothing wrong. Any ideas?
  • John Twist Jan 20, 2010
    I have run into this problem several times in the field. There is almost no answer for it, it just starts happening. I have never been able to find a solution to it. Replacing the fuser will not stop the noise... There is a plastic piece that is supposed to provide a specific gap between the fuser gear and the output gear and I tried modifiying that by increasing the gap just a little bit, it stopped the noise, but it also began getting printer jams at the fuser.
    Genius:
  • 1,089 Answers
Common problem. The fix is to change the fuser AND the fuser idler gear - RU5-0957-000CN. It is a 20 tooth gear. As the teeth wear the noise gets progressively worse.
Posted on Jan 24, 2010
Testimonial: "That was good advice "
    Problem Solver:
  • 9 Answers
Needs a new fuser, but will work fine for a while. If you can stand the noise, go for it.
Posted on Jan 20, 2010
  • jmcdani1 Jan 20, 2010
    I've had this happen to many of these printers, also, and it is almost always the fuser, but is just my opinion...
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Grinding noise
"Swing plate assembly" (RM1-0043-020CN) need to replace to avoid grinding noise. ..Note: Only professionals can perform this activity..
Jan 23, 2013 | HP LaserJet M4345 MultiFunction Printer
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Turned on the printer and hear a clicking/grinding noise back by the rollers that exit the paper - can not print How to get whatever is jamming movement resolved?
If you remove the Fuser Assembly and look at the black gear to your left, you will find what is call a Swing Plate Assembly. When those gears gets worn it will cause the Fuser gears not to engage properly and cause jamps and loud noise. Some times you can get by replacing just the gear you can see. If you have to remove teh complete assembly, it is quite a chore and shoud be done by a service technician.
Jul 20, 2011 | Brother HL 1250 Laser Printer
When i power up the printer it make a loud noise. It appears to come from lower area below the cartridge. it makes the noise even if the cartridge isn't in
If this is a grinding noise it will be the gear assembly near the fuser on the printer. You would need a printer repair person to fix this for you.
Mar 08, 2011 | HP LaserJet 3320 All-In-One Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Malfunctioned
You problem is not (usually not) the output roller at all but the gears located on the sidewall on the left inside the caity where the fuser installs. There is a repair kit out to fix all of the issues relating to the fuser grinding, machine noise and output roller issues all at one time. It's available at Seattle Platen 1-800-221-2388. Just ask for Dale and tell him you need the 2400 gear repair kit. It runs 10 to 15 dollars.
Hope that helps you.
Jul 16, 2008 | HP LaserJet 2420 Printer
Major problems when trying to print, Jamming alot & grinding noise
If the paper is an accordion type jam, you should replace the 4 small rollers, the upper feed roller, the upper feed guide, and the lower rollers. all of these are listed on hp's part surfer website.
RF5-0425-040cn, RF5-0434-000cn, RF5-0432-000cn, and RF5-0438-000cn respectively. Basically, get a new exit output assembly part number RG5-0456-180cn.
Does this help?
Jul 09, 2008 | HP LaserJet 4 plus Printer
LOUD thumping noise when printing
Fuser/ upper heat roller/film or lower pressure roller has lost it's coating, nees new fuser assembly (hot bit at back) about $150 plus labour
Oct 12, 2007 | HP LaserJet 1300 Printer
HP LaserJet P3005n Printer Logo
973 people viewed this question
Seeker5211
Seeker5211
