Question about Garmin 010-00358-00 GPS Receiver
Touch screen does not work
My touch screen does not allow me to navigate the street piolt. The unit power up fine but I can't get past the home page. I there a reset for the touch screen?
  • 1 more comment
  • TC42 Jan 29, 2008
    The touchscreen on my 2610 will not calibrate, any ideas?
  • LucianoCampo May 13, 2008
    mine just did the same, where you able to find the solution?
  • atwillfarms Aug 27, 2008
    my 2610 touchscreen does not let me navigate, even with repeatably recalibrating
    The outside screen (like a fine film) deteriated, the sceen is now verydificult to read.
My c330 has a reset button if you take the outer frame off, and it's on the right hand (center) side. Also, I was having issues with my screen too. I work in construction, so I cleaned it around the screen and found a small piece of something which was obstructing my path. I cleaned it, and it works fine.
Posted on Dec 29, 2007
Access to home page on Kindle touch
Wake the Kindle by pressing the button on the bottom edge of the device next to the USB jack. Then after the unit wakes up, navigate to the home screen by pressing the button centrally located on the front of the Kindle below the screen. (I doesn't look like a button, it resembles a grille and consists of 4 black parallel lines.) The home page will pop into view unless you were already there upon waking up.
Jan 24, 2016 | Amazon Kindle Touch Screen Wi-fi W/...
The touch screen is not working properly when you
Turn the unit off and make sure the power cable is disconnected as well, get a good SCREEN cleaner. Not the same as Windex or other product. Clean the screen well, you need to get rid of the oils and dirt on the screen. Once you are finished and the unit has been dried off power the unit back up and in one of the submenus you will find a screen calibration option. Use this and you should then be finished and the unit should go where you touch. Hope this helps
Jun 19, 2010 | Tomtom ONE 3rd Edition GPS
I forgot my pass code. how can i reset my ipod touch.-
If your iPod touch is password locked, the only way to get past it is to force the unit into restore mode by doing the following:
1. Plug the iPod touch in to your computer.
2. Hold the sleep/wake button and the menu button down at the same time. Keep them both pressed until you see the 'restore' screen (an iPod cable and an iTunes disc symbol) on the iPod touch. Release the buttons.
3. iTunes should now display the iPod touch, along with a message that the iPod touch is in recovery mode. Click the RESTORE button in iTunes to restore the iPod touch.
Please note that doing this will erase the contents of the iPod touch -- that's how the system is designed to work: a passcode lock is meant to protect the data on the iPod.
^This works too, but if you have important data on it you can hold down the on/off button and the square button until it goes off , and then press the square button to get it to turn back on. I had to do it too :(
dont forget to rate me....
good luck....
Apr 19, 2010 | Apple iPod touch
How to change home address
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
Sep 27, 2009 | Garmin nuvi 265 Car GPS Receiver
Not speaking street names
To get your TomTom to speak street names, you will need to change the voice from a recorded voice to a computer voice. This can be done by:
  • Connect your TomTom to your computer
  • When the TomTom asks do you want to connect to the computer, choose Yes
  • Open the TomTom Home application
  • Click on the 'Add Traffic, Voices, Safety Cameras, etc.' button
  • Click on the 'Voices' button
  • Click on the 'Computer Voices' button
You can now select a voice to install on the device.
Once you have installed a voice, change it by
  • Disconnect the TomTom from your computer
  • Turn on the TomTom
  • Touch the screen to bring up the menu
  • Touch 'Change Preferences'
  • Touch 'Voice Preferences'
  • Touch 'Change Voice'
  • Use the Left / Right arrows to navigate to the voice you just installed (Look for the word 'computer' in the upper right corner by the male/female option)
  • Touch the 'Select' button
Apr 07, 2009 | Tomtom One XL GPS Receiver
Not too computer literit. Tomtom has taken me to a bridge that has been closed for a year. Tried an address and it took me to an open field(twice). Purchased it in Dec. '08 i would think it would have...
From the navigation screen (first one you normally get after power on) touch the map part of the screen; more options (right arrow); Map corrections; Correct a map error; (Un)block a street; On Map; find the bridge on the map and touch that location; Done; touch Eastbound; touch Westbound (or similar words) so they now indicate as blocked; Yes (confirm change is permanent).
The Satnav should no longer use that bridge in attempting to calculate a route.
Hope that helps.
Jan 19, 2009 | Tomtom ONE GPS Receiver
Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Jan 11, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
80 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
