Keep gettting pop up box ''out of memory at line 129'' can anyone help? cheers
  • 40 Answers
When this error occurs.. hit ctrl-key alt-key and the delete key simultaneously to get in to view how much memory is available on your laptop....
if your out... or close to that
go under start ->settings-> control panel -> system -> advanced menu
then enter the performance area.. click advanced tab...
set the page file size to 12000 and this will likely solve the error
or a piece of memory may have an error.. or the software needs reinstalled.. or the hard drive is corrupted.. or the software has a bug...
Posted on Sep 30, 2009
2007 bmw x5 fuse 129 keeps blowing
change the central locking relay.
Dec 13, 2013 | BMW X5 Series Cars & Trucks
Compaq c700 is getting slower, keeps popping up not responding, freezes when looking through photos..gettting worse last few months ..help?
Follow these guidelines: WebRepOverall ratingThis site has no rating(not enough votes)
  • Scan your computer with an antivirus
  • Apply De-fragmentation on your system
  • Run disc clean up
  • Fix registry errors
  • Delete all temporary files:
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is opened delete EVERYTHING that's inside it.
For complete PC optimization i would suggest to use system utility tool Intel Software Partner Reginout.
Dec 12, 2012 | Computers & Internet
Projector menu keeps popping up after Directv box change
Is the projector menu that comes on the menu that tells you the projector is not receiving an input signal?
Dec 18, 2009 | Refrigerators
Why do I keep getting the message-Out of Memory at line:129??
Check the ram usage on the specs in the task manager . If it is not nomal then try the ccleaner . That should help. Or try the system mechanic program to clear up the ram .
Oct 19, 2009 | Computers & Internet
Block pops up saying ...out of memory at line 123
Facebook and Vista are both memory hogs.
Options:
1. Use http://lite.facebook.com 2. Use a better browser. http://browsehappy.com/ 3. Buy more RAM. It's cheap. Your time is not. Don't waste time with a slow computer. 4. Vista. There are better options. Most options are better, actually.
Sep 30, 2009 | Microsoft Windows Vista Home Premium with...
What does "mother board compromised" mean? I had a bright house tech out and he replaced the high speed eithernet card,and told me the computer may not keep up.Now i cant get on line or it freezes up or...
motherboard compromised , from my experience, is a setting that has been trigged in the BIOS on the motherboard (ie the memory chip that saves system settings like RAM speed etc).
The trigger was umm, triggered when the PC case door was opened.
There's probably a sensor under the case door like how a car alarm goes off if someone pops the hood.
This should be able to be reset from within the BIOS, so when you turn your PC on, press Delete, or F2 or whatever your BIOS toggle button is. (it usually tells you on the first screen you get when the PC is switched on.)
Sep 21, 2009 | Compaq Presario 5461 (152508-003) PC...
Wount start backfires
Most likely the electric fuel pump in the tank is bad. You will here it hum while cranking. The failure is that the pump is not pumping enough fuel to keep the engine running. There are plastic tubes on the pump that deteriorate and get pin holes in them and leak fuel and lowering the volumn of fuel.
Also remove the vac. line to the fuel pressure regulator on the fuel injector rail. The fuel pressure regulator has a history of leaking fuel into the vac line and flooding out the engine. (Wear saftey glasses when removing lines)
Sep 08, 2009 | 1999 Chevrolet Silverado 1500
Black box/ border keeps appearing
Go to System Preferences>Universal Access, now make sure "Voice Over" is turned "Off."
Hope this helps!
Aug 24, 2009 | Computers & Internet
88 frd trk dies when it gets hot
That part is called a "fuel inertia cutoff relay". It's there in case of a collision.............and cuts off the flow of gas. Sometimes it will pop up after hitting a large bump or jarring motion, while driving. Not B.S.
May 22, 2009 | 1988 Ford F 150
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
