Question about Disney Pix Micro Digital Camera
How do I get the pics off the camera and on to the computer
Problem in pics diplaying on computer
It sounds as if you are not actually downloading them into the PC. Read the manual to find out how to do this.
Dec 26, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
My camera will not upload pics, it says that there is no pics/videos to upload at this time! Even though I have 84 pics there!
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 24, 2012 | Kodak EasyShare C143 Digital Camera
Stoplight shows even though all pics have been downloaded
Do you happen to be on a Mac when you downloaded the photos? If so, make sure to empty the trash (while still having the camera plugged in) after you delete them.
Apr 11, 2010 | Fisher-Price Kid Tough Digital Camera
I used my camera to take over 100 photos,I downloaded a pic from the Camera to the COMPUTER. In later that day I tried to used the camera and it's said file error.
If I understand, you downloaded 1 pic from a total of 100 pics. Did you then delete that 1 pic using the computer to do so instead of the camera? Or, did you yank out the USB cord without using the "safely remove hardware" icon at the bottom right of your computer screen? Either one of these can cause your problem.
Jan 29, 2010 | Vivitar ViviCam 8025 Digital Camera
I uploaded pics from my computer onto my Camera SDPhotosmart M537
If I understand you correctly, you put pics onto the SD card using the computer, then put the card in the camera and now can't see the pics? Is that correct? The camera won't recognize the pics because it uses a different recording system than the computer. Now if you want to take more pictures using that card, you will need to format it in the camera first.
Oct 05, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Had no problem before. Went to upload pic's to my computer and pic's will not upload In dialog box I press " print pictures to folder on my computer." Then pic's do not upload. I have a FinePix A120...
you could try doing it manually, go to my computer open your camera, and select your pic files and ctr+c and ctr+v on folder where you want them to be or just drag them to my pictures folder or wherever you want
Aug 01, 2009 | Fuji FinePix A120 Digital Camera
Camera wont turn on after trying to download pics to computer/can't find pics on computer now
You probably had a bad USB connection that supllied to much voltage (or had a bad ground or reverse polarity) to the camera and shorted out the circuit board. Disconnect all cables. Hook up to a charger and try again. If this does not work, the camera is fried, sorry.
May 07, 2009 | Kodak EasyShare V1003 Digital Camera
Pics from comp back on to camera
Did you take the pics with the camera, or are they just pics on your computer that you want to put on your camera?
Jan 14, 2009 | Kodak EasyShare C613 Digital Camera
Photos will not upload from camera to computer
Go to Desktop/MyComputer/Pana(or it may say USB Drive, or DCIM, and click on this external drive Icon.
You are now looking at the camera contents as if it were just another file folder on your PC, and behaves the same way.
You will find your pics in a sub-folder under a master folder, common for all camera file structures, named DCIM. You can drag and drop individual pic (jpg) files or whole pic subfolders from the camera to a place on your PC, usuallly Documents/Pictures.
You can do all other folder/file operations on this Camera Folder/Pic files you can do with those that exist on the PC like;cut, past, delete, rename, etc etc.
When you take you next first pic from your camera, after moving or deleting a pic subfoler under the Camera's DCIM master folder, the camera automatically creates another subfolder. Each subfolder holds 999 pics. The camera will atuomatically create a second, third, etc subfolder for pics 1000 to 1999, 2000 to...etc.
Nov 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Disney Pix  Micro Digital Camera Logo
67 people viewed this question
Top Disney Cameras Experts
mohamed salim shaikh
venugopal durairajan
Are you a Disney Camera Expert? Answer questions, earn points and help others
