Question about Kodak EasyShare C613 Digital Camera
All pictures are over exposed and appear very bright when reviewed on the screen and on the computer this is something that has only just started to occur
    Sergeant:
  • 151 Answers
Hi.
For this you can try doing the following:
  • Set the camera mode to Auto Mode
  • Take some pictures
  • if the the same results appear call the Tech Number
18002356325
Hope this will help
Thanks
Byron
Posted on Sep 29, 2009
    Brigadier General:
  • 11,967 Answers
Did you change the ISO setting to a high number? Try going into the setup menu and scroll to "reset"...follow the on-screen instructions.
Posted on Sep 30, 2009
All outdoor exposures are white.
Sounds like you ISO setting (the 'film' speed) is set WAY too high. The brightness outdoors is causing the camera to not be able to expose correctly within the parameters of lens aperture and shutter speed. Try setting the ISO at 200.
Oct 04, 2015 | Canon PowerShot Cameras
Picture dark
Locate the Fn (Function) key on your keyboard.
It may be on the bottom left side with dark blue letters.
Locate the two "brightness" keys near the top of the keyboard.
These will be in the "F" keys, possibly if F6 and F7.
They should have little sun pictures or something similar to indicate brightness.
Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness.
Tap F7 repeatedly until you reach the desired brightness.
Fn must be held down as you continue to tap.
check vga card
Click the Windows orb logo at the bottom of the desktop to show the start menu.Click the "Control Panel" from the menu to open a window.
Type "troubleshooter" in the search box in the top-right corner of the window.Click the "Troubleshooting" link that appears in the center of the window in the search results.
Click "View All" in the left pane of the window.
Click "Display Quality," and Windows will begin checking the computers video card adapter. Monitor the screen, answer the questions and follow the instructions if a problem and solution are given by Windows.
Feb 20, 2014 | Computers & Internet
When i take pictures,horizontal lines appear and brightness is more
From what you said - it sounds more like a sensor problem in the camera.
If the screen looks OK while sizing up a picture , then 'click' Image is stored on sensor which is read as one LARGE matrix of dots and stored into memory.
If the white lines start at this point - ie. viewing the picture while in camera and then after download.
Then, the problem started at the sensor.
I just did a (www.goggle.co.uk) and did a search for problems - and NONE apart from Wi-Fi connections to Windows7 -- all reviews were great.
I would connect Nikon to see what they recommend
Feb 11, 2011 | Nikon Coolpix P2 Digital Camera
Orange blue lines, image over exposed for outdoor shots
You might have chosen either to fast an ISO (i.e. 800 or 1600) or you have too much light entering the lens (sensor) in other words the automatic exposure is turned off manually or there is a fault, check first the menu options as a rough guide you should have the ISO set around 200 - 400 the aperture set around F6.3 to 8 with a shutter speed at 200 ish, all this depends on the brightness of the day but if you have auto exposure on which every new camera would have these days then that is all taken care of. Try different SCN and ISO to see if problem still persists. If the problem is intermitted, try to find a pattern in to when the faulty pictures appear.
Or else try to remove the memory card. Turn On camera without memory card, now press menu button and go to setup menu and under setup menu please look for format then press Ok, under format please format the internal memory. Now if you already reformat the internal memory, take atleast 3 pictures on a same subject, then hit review if the lines appeared on both pictures on same location, it means camera needs of service please call Kodak toll free 1 800 235 6325., For U.S and canada support.
Thank you!
May 17, 2010 | Kodak EasyShare Z612 Digital Camera
Bought this product on 28/03-08 at bangalore.all snaps taken out-doors becomes too whitish and not able to see anything, the lcd screen on review shows no snap..but white over exposed result even at...
make sure your ISO setting is set to Auto. Even in auto mode its possible to set your ISO manually. If the ISO is set to auto and the pictures are still to bright, your sensor may be bad. Also make sure your exposure compensation is set to 0.
Mar 20, 2009 | Kodak EasyShare C613 Digital Camera
Over Exposure in bright lights
Please click Sony Support to download user manual of DSC-T3
Jan 11, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Monitor display prob
Here are some basic trouble shooting tips for new monitors: The picture does not appear
Check to make sure the signal cable is firmly connected in the socket.
Check to see if the computer system's power is ON.
Check that the Brightness Control is at the appropriate position, not at the minimum.
The Screen is not synchronized
Check that the output level matches the input level of your computer.
Make sure the signal timing of the computer system is within the specification of the monitor.
The position of the screen is not in the center
Adjust the H-Size, H-Phase or V-Size, V-Center controls.
Check if the signal timing of the computer system is within the specification of the monitor.
The screen is too bright or too dark
Check if the Brightness or contrast control is at the appropriate position, not at the maximum or minimum.
Check if the specified voltage is applied
Especially, check the horizontal frequency.
The screen is shaking
Move all objects that emit a magnetic field, such as a motor or transformer, away from the monitor.
Check if the specified voltage is applied.
Oct 19, 2008 | Computers & Internet
LCD/EVF screen come on but is "snowy"
The problem is the lens is not opening, If you look into the lens you can see it is closed. This will require a trip to the repair shop.
Aug 16, 2008 | Kodak EasyShare Z650 Digital Camera
Only see bright light effect in viewfinder and LCD
the Screen has failed or a connector to the main board has come lose. Check out the Makers help line for advice. The likely cost of a repair is going to be high be prepared for a new camera.
Oct 29, 2006 | Konica Minolta DiMAGE Z2 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
43 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
