Question about HP Photosmart C4150 All-In-One InkJet Printer
Paper Jam ..Lost the instructions need to know how to remove the back to fix the jam
Turn printer off. Look at the back of the printer; there is a dark gray panel with a little oval shaped tab on the left. Press the tab to the right and the panel will pop off. I could have sworn there was no paper jam; sure enough there was an old AAA card that had gotten caught up in the rollers.
Posted on Oct 31, 2009
    Scholar:
  • 67 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00651302&cc=us&lc=en&dlc=en&product=1832919
The above link has the instructions to remove paper jam for your model, it also has a video that would help you.
Posted on Sep 29, 2009
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
Printer jam
If your paper is jammed inside, open the printer and gently pull the paper back out to fix the problem.
May 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper jam
Hi......................
How to Clear a Paper Jam on an HP Inkjet Printer?????
Paper jams are among the most common problem with HP inkjet printers. Follow these instructions to learn how to clear a paper jam so you can get back to work.
Instructions Things You'll Need
  • HP inkjet printer
    • 1 Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    • 2 Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
    • 3 Look for paper through the opened back panel. Remove any paper you find jammed.
    • 4 Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
    • 5 Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
    • 6 Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
    • 7 Close the front access panel. Make sure that it latches back into place.
    • 8 Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this will helpful to you...................
Good Luck.............
Sep 24, 2011 | HP DeskJet D1460 InkJet Printer
Paper jam - where do I get instructions on how to fix?
To remove the paperjam in machine you need to:
Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well. Remove the paper tray there could be a piece of paper stuck there.
Wherever you find the Jam remove it slowly so it doesnt rip.
Jun 24, 2010 | Brother HL 2140 Laser Printer
JAM E, UNNABLE TO CLEAR ERROR
Jam E normally cause by the paper path sensor came off during when you clear a paper jam.. the sensor is located at middle side , to fix it back you will need to remove the E cover..and remove the transport unit...4 screws.. but putting it back will need to have some technical know how as fitting it back wrongly will cause you unit not able to feed paper due to the plastic blocking the paper path.
Will upload some instruction later...
Apr 14, 2010 | Epson Aculaser C1100 Printer
Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps.
Aug 08, 2009 | HP Office Equipment & Supplies
6110xi paper jam, or something worse?
Actually, the "paper jam" message can be displayed due to a variety of jam locations and other causes. Starting by looking in the back of the printer is a good first step, but you can have a jam in the front or even in the automatic document feeder (although that one should be apparent because it's sticking out the front end.
HP.com has a web page that goes into a lot of detail about where to look for a paper jam and what other conditions in your product might cause such a message to occur. The solutions are available as well. Take a look here:
Paper Jam error
Try those solutions and post back your results. Good luck.
Nov 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Savin 2513 Jam
Many printers have a paper jam alert.But you need to remove the jam the correct way. You can't just pull the paper from the machine. If you have the manual--look up the proper procedure to un jam the paper. The machine can detect if the paper is stuck and it will not know it is fixed if the proper method isn't used. The system has a mechanism that loosens the rollers to allow the paper to be removed without damaging the wheels.
Oct 12, 2008 | Office Equipment & Supplies
Paper jam
on the back side of the printer there is a assess door to remove the jammed paper in the printer.it has a channel like button on the backside.just rewind the channel to unlock the assess door and open the door towards you.and the door will come out into your hand.just remove the paper jam clearly look for any tiny pieces of paper in it.and then reverse the procedure to lock the door again.
Oct 05, 2008 | HP PSC 750 All-In-One InkJet Printer
HP Photosmart C4150 All-In-One InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
