Question about Altec Lansing ATP 3W Computer Speakers
No sound - led shows power is off
I've put all the cables according to the manual, the input/output cable is connected to the right place, the power plug is connected to a proper socket. I have no idea what might be wrong. The output/input cable does not make any buzz sounds at all when pulled out or pluged in.
  • Anonymous Mar 09, 2009
    Same problem, its like it is dead. I checked the fuse in the sub, its fine.. not sure what the problem is.
    Problem Solver:
  • 5 Answers
Ok lets do like this
If you your mother board CD ,? get play that and you will find an option for sound and audio devices , please reinstall that.
I hope it will work .Please do reply..
Posted on Dec 22, 2007
Where is the Audio out on model NSA-40d40sna14
It is on the HDMI cable, or there is one audio output. Did you read the manual?
3 HDMI inputs for the best home theater connection:High-speed HDMI delivers a full 1080p picture and digital surround sound in one convenient cable. HDMI cable not included. Additional connections:Provides flexibility with component and PC inputs, a USB port and a DVI interface. 1 audio output.
Manual under Support and Downloads
Insignia 40 Class 40 Diag LED 1080p 60Hz HDTV Multi
Dec 14, 2016 | Computers & Internet
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Can't get surround sound when watching normal tv,
Have you looked at the manual?
The specific product you're inquiring about is not showing in your post. Name the make
and model first, then we'll ALL look for the manual. Then (maybe) find a solution. You
might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
HDMI can be either an input or an output. You don't specify what the HDMI is carrying and to what or from what?
TV-related multichannel audio almost always originates with a digital program source which today os usually the Cable Box. THAT would be a good place to start with the attempt to get 'surround sound' after you've decided how to use the digital input on your unnamed HTS.
Jul 02, 2011 | LG Audio Players & Recorders
My problem is how to connect marantz audio video receiver 680 to LED samsung 42"
Hello, you need to connect the sound output and video output of the TV. To the entry of sound and video of the amplifier. Should match the cable type, the type of connection to existing instruments. Usually connections are RCA connections or SCARET. Once you have connected, you need to choose the entrances of the amplifier switch, according to entries you've used. What remains is only to increase the volume. Good luck
Apr 22, 2011 | Televison & Video
I change Component Cable Video & Audio 6 cables
I might sound stupid but Double check that you`ve connected the correct connectors as in All Inputs plugs being used or All outputs plugs being used. If you have one of these leads with 6 connectors on one lead, (Audio Input L+R, Video Input, Audio Output L+R, Video Output) You need to make sure that if you get sound from the audio input plugs, then you must use the video input plug and vice verse. Ian
Jul 22, 2009 | Panasonic PV-D4732 DVD Player / VCR Combo
Red light is on when i connect input cable earthquake 1000w amp
Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Cannot connect my home cinema system to play my tv sound
what system does it have aux input on screen showing right input u pluged rca cables from tv rca outs to sterios ins right or cable box outs to sterio ins red white rca cables right make sure tvs output sound is on in menu thx nick
Oct 06, 2008 | Samsung Televison & Video
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
Altec Lansing ATP 3W Computer Speakers Logo
250 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
