Question about Garden
Gas Push Mower - Briggs & Stratton, will start but run for
Gas Briggs & Stratton, will start but run for only 30 seconds. Changed plug & filter already, drained all gas just in case it was bad. Was told it could be carb. or manifold?
I've looked up parts for both but not sure what problem to look for.
12F802-1977-E1
  • 437 Answers
The jet in the bottom of the carburetor is clogged up. The engine will prime but after that fuel is burned off, the engine stops. The jet is not allowing fuel to be sucked into the engine.
Posted on Sep 30, 2009
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
I have a Briggs and Stratton 625 series mower that will start but not run for more than 30 seconds. I was told to change the spark plug. I noticed that there is oil on the spark plug and in the hole where...
Sounds as if the problem is in the fuel system. When water develops in the tank, the weak fuel cannot keep the motor running. Use a solution for removal of water condensated gas tanks.
Mar 12, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
5.5 Briggs & Stratton push mower running too loud
It could be the govenor spring. Get the model number, type and code and take it to a small engine parts store and get a new one. A new spring will slow down the rpm's and it wont be that loud. Make sure you remember how the spring was hooked up.
Let me know if this helps.
Thanks \
roundo4
Aug 25, 2009 | Garden
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
505 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
