Hello...
I have a proview monitor i guess the model is something like PA 458.
I needed to clean the monitor from inside because of lots of dust in it. I cleaned with the help of a soft cloth. After i cleaned and fixed back i am not able to switch on the monitor. It makes some sound behind the picture tube (Tick Tick sound). Power button seems to be working fine but it never displays anything.
Can anybody help me about that?
Thanks and Regards
Vikram
SOURCE: green led light flashing on 700p proview flat panel and no picture
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
SOURCE: no power when first plugged in the power light blinks
ok I have posted a fix for this but I will do it again it will require some soldering technique unplug the unit from the wall and the computer and set it down on its face(lcd side down) open the back of the unit and disconnect the lcd unit and the backlight power leads. remove the screws from the power unit cover. remove the screws from the vga board then gently pull up the board turn it over and you will see a grouping of 6 capacitors that are blown you may also see another single 120 mfd at 25 volts blown the capacitors are rated 470 mfd at 25 volts but look at the side of one when you have unsoldered it to make sure you get the proper capacitance . make sure you solder in the capacitor the correct way there is a neg and pos side to them and they switch sides halfway through the reworking. reassemble the unit and plug in the back light power leads and then plug in the lcd unit to the vga lead make sure its securely pushed onto the connector re screw the ten screws and then reattach to the computer and plug in the wall and the lcd should come back to life. be very careful doing this kid of work
SOURCE: Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
SOURCE: my proview monitor is not getting on i want customer care no
CUSTOMER SERVICE AND TECHNICAL SUPPORT DEPARTMENT
To contact the Proview customer service or technical support departments, please use one of the following options:
By Phone:
Service Hotline: (800) 776-8439
Office Hours: 8AM to 6PM Pacific Time
By Email:
Customer Service
Email: [email protected]
Technical Support
Parts
SERVICE CENTER LOCATIONS
U.S.A.
CALIFORNIA SERVICE CENTER - PROVIEW TECHNOLOGY, INC.
Add: 7373 Hunt Avenue, Garden Grove, CA 92841, U.S.A.
No walk in service at this facility, all repairs or inquires should use one of the options listed above.
TEXAS SERVICE CENTER - PROVIEW TECHNOLOGY, INC.
Add: 10849 Kinghurst, Ste. 120, Houston, TX 77099
Service Hotline: (281) 530-4100 / (281) 530-4104
Office Hours: 8AM to 6PM Central Time
Taiwan
PROVIEW ELECTRONICS CO., LTD.
Add: 13, Lane 195, Yung-Fong Road, Tou-Cheng City, Taipei 236, Taiwan, R.O.C.
QA Department
Contact person: Robert Tsai
E-mail: [email protected]
China
PROVIEW TECHNOLOGY (SHENZHEN) CO., LTD.
Add: North Block 21, 23#, Shataukok Free Trade Zone, Shen Zhen China
RMA Dept.
Contact person: Dennis Chang
E-mail : [email protected]
Brazil
PROVIEW ELETRôNICA DO BRASIL LTDA
Add: Rua Acará, 203, Distrito Industrial, Manaus, AM, Brasil, CEP : 69075-030
RMA Dept.
Contact person: Cintia Andrade
Europe
EUROPEAN REPAIR CENTER
Add: PGL Europe Service Centre, Van Elderenlaan 28, 5581WJ, Waalre, The Netherlands
Contact person: Chris ****
Bulgaria
LAN Service Ltd.
Add: 140 Mimi Balkanska Str. office Transpress, 1540 Sofua, Bulgaria
Tel: +359 2 960 2360
Fax: +359 2 960 2369
U.K.
WARRANTY SERVICE CENTRE
GOODIES ENTERPRISES LIMITED
Add: Mile Road, Bedford, Bedfordshire, MK42 7TB, United Kingdom
Service Hotline: 0870 7572944
Fax Number: 0870 7315018
Russia
PROVIEW RUSSIA LIMITED
Add: Bolshaya Novodmitrovskaya street 14, building 2, office 424, 125015 Moscow/Russia
RMA Dept.
Contact person: Ralph Leonhardt
U.A.E.
PROVIEW MIDDLE EAST.
Add: P.O.Box 18349 Jebel Ali Free Zone, Dubai, UAE
RMA Dept.
Contact person: Liza Manawis
Iran
ETIG LTD.
Add: Suite 3, #8, 16th St., Asadabadi Ave., Yousefabad, Tehran 14318, Iran
Contact person: Farshid Safinia
