It sounds like your hard drive has crashed if all you're hearing is clicking noises and it no longer works. Unfortunately if this IS the case, you can't get the data off unless you have tons of money to pay a forensic data recovery specialist (crazy expensive). Sorry buddy.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Quick response... even though is was bad news. Well at least I know where I stand. Thanks, MC
" - mike68195
I purchased a new power cord for $19 and everything works fine now. Before the light would be on but the unit would not start. I was so relieved when the power cord fixed the problem.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE. Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason. Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear. Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
This very same thing happened to me. There is no way to retrieve the data unless you want to send it to some company that will take it apart, put your platters in another drive and get the info that way. I checked it out. Estimated cost, 3-4 thousand dollars. Yes, that is not a typo. Sorry to say, but your drive is gone.
Was this helpful?
Yes
No
Popular Solutions for Maxtor Personal Storage 3200
Changed p.c. from vista to windows 7. hard drive will not work, any ideas how i can over come this...
(More)
Changed p.c. from vista to windows 7. hard drive will not work, any ideas how i can over come this please
I have a Mac (OS X 10.4.11) which I have connected a Maxtor 3200 L42V9WCG...I previously stored...
(More)
I have a Mac (OS X 10.4.11) which I have connected a Maxtor 3200 L42V9WCG...I previously stored files form a windows machine but I can not seem to store anything from the Mac to it...I get an error that says the folder I'm trying to store to 'can not be modified'....under info/ownership and permissions/ it says read only with no option to change it..can you help me?
