Question about Sea Gull Lighting 1555-734 Three-Light Cypress Grecian Stone Ceiling Fan
2 ceiling fans with the same remote code.
Me and my neighbor both have a fan which exactly look like the one in the picture and they have a same remote code. When my neighbor change the speed of the fan, my fan speed changes as well. When my neighbor turns off the light, my light turns off as well, and when I turn on my light, my neighbor's light turns on as well, and he turned off the light and my light turned off. How do I change the remote code of my ceiling fan?
bigg t
  • 640 Answers
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
is the fan single phase or three phase?in other words does the fan connect to 2 or 3 wires?if it connects to 3 wires just change 1 wire to another.
Posted on Aug 12, 2007
SOURCE: hampton bay ceiling fan...where exactly is the code for the remote on the fan
i have 2sets of wires coming down from my ceiling and the prints did not come in my box for wireing them what do i do
Posted on Jun 17, 2008
SOURCE: The Hampton Bay Altura Ceiling fan functions only with remote.
You can hard wire this fan to 1 or 2 switches, bypassing the remote unit entirely. NOTE: You will only have 1 fan speed and no light dimmer. Set the fan at the desired speed and direction using the remote system PRIOR to hardwiring. The fan will remember the speed and direction.
Connect your house wiring directly to black and white (and blue if lighting is required) wires. With a 2 switch system, your third house wire should be red. Connect the blue fan wire to the red house wire.
Your 2 switches will now separately operate the fan and light functions. As stated earlier, you will only have 1 fan speed and will be unable to change the direction, so set your desired speed and direction before you rewire.
Hope this help!
Nick
Posted on Nov 30, 2008
SOURCE: Hamilton Bay Remote Control Ceiling Fan
Rempte light comes on but does not activate fan or light?? thanks
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
Cant change remote code
Don't forget you have to change the codes in BOTH the receiver & transmitter.
Nov 30, 2013 | Hunter Ceiling Fan Light Remote Control
Ceiling fan lights & fan come on without using remote
on some you set a code in the remote control ..then you teach that code to the control unit ..on others you have to set dip switches on the remote control and on the fan to match .. some of the units have dip switches on the top of the fan motor housing ..some have code setting switches on the control unit located inside the fan .. at any rate the fan and remote have to have matching codes ..
here is some information on some units
http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
sometimes the switches are set correctly but the contacts get dirty .. so on the remote, behind the batteries is the code switches .. you can operate each one a few times to clean them ... remember where they are set ... set them back that way unless you are going to change the switches on the module in the fan ... you can check your neighbors remote to see if its on the same setting .. if so one of you has to change dip switch settings on both the fan and remote.. on some older units the code is fixed on the receiver in the fan .. the code is marked on its box .. that code has to be set into the remote unit and is not adjustable ..
this might be the mfg for the hampton bay fans ..it might be a little help
http://www.kingoffans.com/#/products/FAQ
Jun 05, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Sometimes my hampton bay ceiling fan goes on by itself . It has a remote control switch only. It is a model 08060
you probably have a neighbor with the same remote .. each fan has a set of code switches on its receiver .. what ever code is selected by the little switches on the receiver (box in the fan) also must be set into the remote control (code switches in the battery compartment of the remote) .. either you or your neighbor will have to change their code ..different codes wont interfere with each other ... if the fan came with the remote control then the switches might be available on the top of the motor housing .. remotes that have been added on require that the lamp section be removed to get access to the receiver .. some older fans dont have a code selection .. the code is stamped on the receiver .. in that case then maybe your neighbor could change his code ...
once in a while a strong or local transmitter will interfere and set the fan on .. if you are near a radio transmitter, CB or ham radio ..
May 25, 2010 | Hampton Bay 24002 Ceiling Fan
I need a remote
You can buy a remote kit at most electric or home improvement stores. It will come with instructions and needs to have the receiver installed in the canopy of the fan itself. They usually have dimmers for the lights on them, so do not use CFL bulbs in the fixture. Lowes sells one made by Harbor Breeze for about $30-$40. Good luck.
Feb 27, 2010 | Hunter 23827 Classic Original White 42"...
Fan or light goes on sporadically by itself.
It could be that a neighbor has a ceiling fan with the same CODE that yours is set at. It does actually occur.
Try setting the REMOTE(Transmitter) AND the RECEIVER, located tucked in among the electrical wiring inside the CANOPY which is also called the 'Hanger Bracket', to a different but SAME CODE for each device. The RECEIVER, which will have four 'dip switches', as does the REMOTE, will be a small rectangular box with a short antenna from one end.
Good luck. :)
Apr 04, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan with light fixture remote won't turn it off - help!
Think we've figured out that a neighbor has the same remote code as we do and we will have to change our code. (This fan is out on our screened porch and the homes are close together here.)
Oct 15, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 46056 fan
I have three Hampton Bay Ceiling fans with remotes for eight years. I doesn't help when a neighbor buys the same make and model. So, I had to come up with a different code for mine. I had to change the code for the remote and match it with the code in the fan. To change the code in the fan, that depends on the type of fan you have, some you would need to look on top of the fan and use a skinny stick to change the code, other's you would need to take the light fixture down to get to the controller box to change the code. I have both types, this is how know. PS. if ever, which will happen, if the fan doesn't respond to the remote then you would need to replace the controller inside the fan. Here's the warrenty no. 800.749.3267 for replacement.
Dec 24, 2007 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton bay ceiling fan...where exactly is the code for the remote on the fan
Sep 20, 2007 | Hampton Bay 13087 70450 Carousel II...
Sea Gull Lighting 1555-734 Three-Light Cypress Grecian Stone Ceiling Fan Logo
66 people viewed this question
Top Sea Gull Lighting Dryers Experts
Are you a Sea Gull Lighting Dryer Expert? Answer questions, earn points and help others
