Question about LG LRSC26980 25.2 cu.ft. TV Refrigerator with FM Stereo: Titanium
Tv is snowy; it appears to be with the connection from the TV to the box located on top of the refrigerator. We are not sure how to remove the TV to check the connections.
If the connections are good, it could be bad capacitors on the TV board. If you are comfortable with electronics, the service manual explains how to remove the TV fascia. From there, it is easy to get to the "guts."
Posted on Aug 18, 2013
I just purchased a Samsung40" 4K Ultra HD HDR LED tizen smart tv 6270fxzc it has little white dots (snowy) on the screen picture?
Take it back it is likely defective if you know for sure you have a good TV signal. Do other TV's you own have this snowy appearance (white dots)
Nov 29, 2016 | Ultra Televison & Video
1999 36" SONY FD TRINITRON VEGA #
It sounds that the tuner to your TV is faulty. It should be replaced. Before confirming, check the antenna connection for firmness, and the antenna wire have no breaks inside it. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Apr 23, 2013 | Televison & Video
Sony KDL-V32XBR1 Displays only snowy picture
Here are a few more troubleshooting steps you can try when your TV picture is just snow. I see that you have already rebooted your TV, but did you turn your set-top box off and on, too?
1. Does the picture show when you play a DVD?
2. Check all of the connections between the TV, outlet and set-top box and make sure everything is secured.
3. Is your TV set to the correct channel (typically 3, but in some areas 2 or 4)?
4. Press any key on the remote to see if the correct mode lights up. (Ex: if you have cable, the cable button should light up). If it doesn't, press the correct mode's button to regain control and change channels.
5. Call your service provider and make sure it's not an overall service outage.
6. Do you have sound but no picture? If so, it could mean a backlight failure.
For more suggestions, see TV black screen or snowy screen for troubleshooting and solutions. I hope this helps!
Sep 20, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Connected the coaxial cable to the tv but got no channels. the tv turns on but all I have is snow
Some possible things to check:
1. Are you trying to receive off-the-air broadcasting? If so, you'll need a digital converter box. This set doesn't have a digital tuner, so there won't be any channels for it to receive without the converter.
2. Are you connecting a cable from a cable converter box, satellite receiver or FiOS set-top box? Your TV will need to be set to channel 3 or 4 to see the signal from the device.
3. Make sure the center wire in the plug on the end of the cable isn't bent over, and that it extends far enough (about 1/8 to 1/4-inch) to make a good connection.
4. Do you know for sure that the cable you are connecting is working? Is there actually a signal on the cable? It may be disconnected somewhere else (at a splitter, for instance) or there may not be any signal source.
5. Have you tried another TV to test the cable? If the cable works with another set, the tuner or antenna connector on the snowy set may be bad. If the cable connector is tightened too much when hooking it to the TV, the connector may be damaged and this can cause the snow.
Start by checking with a known good TV. If that one is snowy, you can check the other possibilities. If it works, you'll know the problem is in your set and can decide what to do (repair or replace).
Hope this helps! Thanks for using Fixya.
Nov 08, 2010 | Toshiba 27AF42 27" TV
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
How do we adjust our tv
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box. Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic. If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem. Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
Sep 25, 2007 | Televison & Video
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Refrigerators Logo
75 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
