Question about Fuji Finepix Z20fd Digital Camera
My camera has placed a Protected card ! on my camera without my approval
  • 428 Answers
No! I do not think your camera has placed a Protected card ! on my camera without my approval. Pull out your memory card and look for a very small "latch" at one of its sides. Push it the other way and try to access it again. This "latch" is the "lock/protection."
Posted on Sep 29, 2009
    Brigadier General:
  • 11,967 Answers
Is the slide switch on the side of the card in the locked position?
Posted on Sep 30, 2009
  • Fuji Master
  • 3,289 Answers
Eject the card from the camera and slide the tab on the side to the unlocked (unprotected) position and *carefully* reinsert.
Sliding the card into the camera may be causing it to move to the locked position, and removing it causes it to slide back to unlocked. Try a small amount of scotch tape over the tab and slowly slip the card back into the camera. You may need to remove some tape for it to fit into the slot - so go *easy*.
L20 card is protected. Slide switch is in correct position, put new card in switch in the correct position, same message. Cards work in computer. Removed batteries, hour, and no difference.
The problem may be the card type or size. There are limitations to what the camera can support. Here is a link to a table of supported memory cards (Brand/size/type) that the Coolpix can accmmodate.
https://support.nikonusa.com/app/answers/detail/a_id/16341/~/approved-memory-cards---coolpix-l20%2F-l19
Jul 10, 2016 | Nikon COOLPIX L20 Digital Camera
My fujifilm finepix jx 300 says protect card even after sliding the switch on memory card to unlock
check if in the card slot is any debris. You could try to clean the contacts of the xD memory card with a dry cloth. Place the card on a flat underground and press firmly on the cloth. Don't press without a flat underground, because you could easy break the card.
It also could be some of your pictures are protected. You have to unprotect the pictures first.
Nov 15, 2013 | Fuji FinePix A303 Digital Camera
"card protected " appears whenever i attempt a
Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Then put the card back into the camera.
If that doesn't work, try another card.
Mar 14, 2011 | Sanyo Vpc-s1070w Digital Camera
What is the meaning of card is protected?
Than means you can't erase the data on that card without a password, or administative controls. Someone somehow had requested to make this card protected.
Dec 14, 2010 | Fuji FinePix S1000FD Digital Camera
MEMORY CARD ERROR, CARD LOCKED BUT IT ISN'T LOCKED HOW CAN I FIX IT
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Apr 02, 2010 | Canon PowerShot A530 Digital Camera
Canon rebel xsi gets message card write protected with or without sd card
hi, when i turn on my camera the screen says card write protected? and I can't take pictures on my canon xsi
Jul 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
SD card Protected
It sounds like the tiny locking switch on the SD card has accidently been set to "lock". Remove the card from the camera and slide the switch to the opposite position. That should do it.
Apr 25, 2009 | Fuji FinePix Z10fd Digital Camera
Memory card is write protected
Check the side of your card for a small slide button that moves from Lock to Unlock. Most of the time it is accidentally moved from one position to the other when you insert your card.
Jul 30, 2008 | Motorola Mobility MOTOROKR E6
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Fuji Finepix Z20fd Digital Camera Logo
97 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
