Can't get a test page to print from Canon I1800. Tells me that test page was printed. Can't seem to download drivers, my ''archives' will not accept. Any pointers ?
5 Suggested Answers
SOURCE: Install cartridge
I did a master reset and now it will print but the ink level for the yellow cartridge still shows "empty" even though it is a new one but at least it prints for now anyway.
Master Reset:
Turn off printer and unplug.
Hold down "OK" button and "Help" button and plug in at the same time.
Turn on printer and wait for reset to finish.
It worked for me. Hope it works for everyone.
Posted on Oct 08, 2008
SOURCE: Canon i560 won't print black text anymore
I had the same problem, even when I only selected grayscale printing, my printer would use all 3 colors to make black, and my black cartridge would never get used. Try this:
On printing preferences change your Media Type to Transparency.
This should solve the problem and stop robbing your color tanks when you just want black
Posted on Oct 16, 2008
johnm329
  • 3 Answers
SOURCE: canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Posted on Jan 27, 2009
SOURCE: my canon mp620 won't print the black color.
I had the same problem, after replacing both black cartridges. I solved the issue by running the print head cleaner. Below is the link to the instructions.
For Mac:http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
For PC: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
Posted on Apr 27, 2010
Will print test page but will not print anything else
Hi
I'm guessing that you click on "test printer" on the PC, and the test print will come out. That shows that there is a connection, but it tells us little else. If you still have the original software, I suggest reloading it, as you may have inadvertently deleted the driver - a little bit of software that will send messages from the PC that the printer understands. The driver can also become corrupted or damaged. If you no longer have the software, Canon will have it on their website, I'm sure.
Hope this helps.
Oct 20, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Correct instal of toner + how to print test page [canon LBT 660]
Install your printer driver before.It supported driver win 98.then you can print a test page.
Dec 11, 2009 | Canon LBP 660 Laser Printer
My Canon i850 accepts data from my pc. The printer head seems to go into action, but no print goes onto the paper after it goes through the printer. What could be the cause of this ? I have recently...
It could be a number of things
1: usb cable could be faulty this sending incorrect info across
2: could be something wrong with the actual print head try opening up the machine and see if you can move the carriage left to right by hand
also check if your able to print a test page from the unit itself to confirm it can print without the pc
Nov 10, 2009 | Canon i850 InkJet Photo Printer
IR 1023 iF goed on - doen not print
re-installed the driver after deleting as administrator - power user does not seem to allow certian vista installations.deletions - geez
Jan 26, 2009 | Canon imageRUNNER 1023iF Black and White...
11x17 Landscape will only print 1 page then switches to Portrait
I found an acceptable workaround. If I leave the paper size set to "defined by driver" in the Print dialog box and chose the paper size in the Page Set Up dialog box, that seems to do it. There were numerous complaints on the web about this and it seems to be a major glitch in CS3 with the Leopard OS.
Jan 13, 2009 | Canon imageRUNNER C5180 Color Copier
Canon ImageRunner 2200 printing
the parrellel port is used also to updated machine soft ware.... if you do not have the print bootrom installed it will not print sorry
Dec 22, 2008 | Canon imageRUNNER 2200
Canon IR C3100n copier "NG 853" error
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Sep 17, 2007 | Canon imageRunner C3100 Copier
k24674
jasbo
jasbo
