Question about Shure ULX1 Body-Pack Transmitter Microphone
I have a shure ULX-1m1 transmitter with full battery but will not work. screen comes up green nothing on the display and the battery light is red, what could this be? and how do I fix it
  • Shure Master
  • 5,603 Answers
First, sometimes LCD screens have an intesity/angle control and at extreme range of these characters are sometimes not visible. Check you manual to see if your unit might have such a setting.
Also this unit has some control lockouts so make sure it is unlocked so the automatic frequency selection can be made.
Verify the status of the LED in your manual. MANY Shure mics display the LED red when battery is low.
DO NOT trust a battery as being full because it is new.
ALSO DO NOT USE rechargeable batteries in these as the rechargeable battery does NOT produce 9 volts... usually only 7.2 volts (in spite of the labeling) which is insufficient and will give a low battery indication.
Posted on Sep 30, 2009
Shure ulx
Have you got the body pack attenuation switch set to 20dB? Try it on 0dB.
Aug 29, 2014 | Shure ULX1 Body-Pack Transmitter...
Shure ULX-P4 system is working perfectly well but the TX display does not work. What could this be?
If the display does not work, it will need to be sent to Shure for repiars. www.shure.com/service
Jun 02, 2014 | Shure ULX P4 BETA 58A Professional...
Shure ulx1 pack red power light will not turn green. Pack display does not show any status messages.
Please make certain the battery is good. Put a voltmeter on the battery to make certain it is above 7.5 volts.
If the battery does measure above 7.5 volts, then then transmitter will need to be sent to Shure for repairs.
Dec 20, 2010 | Shure ULX Professional Series Wireless...
I have the same problem. The ULX1 bodypack transmitter displays a RED battery light even when I use different batteries. I have used a voltmeter to test the batteries and they are good. I took the unit a...
I suggest sending the unit to Shure for repairs. The battery indicator is controlled by the micro. Thus, it needs to looked at by a service center that has access to the micro code.
Dec 07, 2010 | Shure ULX1 Body-Pack Transmitter...
Battiers are freash but when I turn on the transmitter, the green light comes on then imediatly goes off.
Call Shure Applications Department at 800-516-2525, option 1 for assistance in troubleshooting.
Oct 02, 2010 | Shure PGX-2 Wireless Handheld Microphone...
Why does my audio light turn from green to amber? and my guitar sound muddy? the battery is new
There are many things that can cause bad sound in a wireless system. I suggest calling Shure at 847-600-8440. Their Applications group can help you troubleshoot the problem. Have the wireless system with you when you call them.
Sep 01, 2010 | Shure ULX Professional Series Wireless...
Shure ULX1 wireless body pack has good battery but Batt light(red) is on and no channel display or output but backlight is lit. Any suggestions
Remove the battery and leave it out for a couple minutes to see if that helps. Also, check the battery with a volt meter to make certain it is above 8.5 volts. I have seen entire cases of batteries that are defective. If the battery checks to be above 8.5 volts and you have removed the battery for over two minutes, then send the bodypack in to Shure Service (www.shure.com/service)
Jul 06, 2010 | Shure ULX1 Body-Pack Transmitter...
Shure Wireless Mike no Output
Check the battery with a volt meter. If the battery measures lower than 8 volts on a volt meter, replace the battery. I have seen entire cases of brand new batteries that are defective. Make certain to check it with a volt meter. If the battery tests fine, then send the bodypack to Shure for repairs. www.shure.com/service
Dec 18, 2008 | Shure ULX1 Body-Pack Transmitter...
387 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
