Question about Maytag Neptune MAH5500B Front Load Washer
My Maytag washer is not start. The door lock is not funtion after press start. It stopped work 2 days ago. I opened the washer and manually turn the door lock switch. After I put it back, it worked again for couple loads and came back the same problem. Any help please
    President:
  • 1,304 Answers
Bad doore latch
Posted on Oct 05, 2009
Lock on washer
On some door lock mechanisms there's a manual release tab either above or below the lock assembly. Old Maytag Neptunes had a cord near the dispenser Simply pull the tab and the door unlocks
Apr 12, 2014 | Washing Machines
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
Washer will not turn on.
If the Add A Garment light is on, try this: the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point.
May 21, 2013 | Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Door doesn't unlock and I can't get my clothes out for two days. I unplugged it and when I plugged the washer and turn it on and press start water comes out, but it doesn't spin. I unplugged it again and...
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
Maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH8700 - NP error code - Door locked and won't open
I don't know if you are aware of this, but Maytag did a recall on this washer in March 2007 where there was a risk of water leaking into the control panel and shorting out the board. You can follow this link to see if your washer was affected based on the serial number:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07135.html.
Here is a link to your user manual to see if it offers any help. The only thing I saw was to use the Cycle Selector button to unlock the door.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/DC6802030B01.PDF
I found this on the Maytag site:
Is the door locked and the Add A Garment or Add Clothes light off?
If the Add A Garment or Add Clothes light is off, then the washer door will unlock after the Pause/Off or Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
You could also try their customer service number to see if they have a script for this problem: 1-800-688-9900
The only other solution I can offer is to disassemble your washer if its that urgent and you can't get a repairman out there.
Jan 10, 2009 | Maytag MAH8700AWM Neptune Front Load...
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
My Neptune washer MAH9700
I have a Maytag Neptune MAH 9700. It died one day and the door remained locked. I am guessing the circuit board is fried so it's a good thing I purchased a five year extended warranty. The problem though, is that my 2 year olds BLANKY was in there and she won't go to bed without it. Can't wait 2 weeks for the repair guy. I was able to remove the top and (after I unplugged it of course) get my hand to the bottom of the switch housing. Seems there is a small opening at the bottom. I pressed up with my finger and was able to get the door opened. Whew!!! Hope this helps. ; )
Jan 10, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
