Question about LG Dishwashers
WHERE DOES JET DRY GO
I DONT KNOW WHERE TO PUT THE JET DRY IN MY LG DISHWASHER, THERE ARE TWO COMPARTMENTS, ONE HAS TWO SLOTS(ONE FOR DISHWASHER SOAP) AND THE OTHER COMPARTMENT HAS A TURN NOB WITH A SUN PICTURE BY IT CAN'T FIND MY INSTRUCTIONS ANYWHERE
    Problem Solver:
  • 5 Answers
The turn nob is a cap that you screw out and pour your jet dry liquid in then replace the nob/cap the jet dry will be dispensed automatically.
Posted on Sep 29, 2009
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
Jan 31, 2013 | Danby Dishwashers
My Mother in law has a G.E dishwasher and she put the dish soap in the wrong spot she put it in where u would put like jet dry or what ever and now wants to know how to get that soap out of there how would...
It isn't a big problem. Just keep using it and put some jet dry in it once in a while. eventually all the soap will be gone.You'll just have spots on your dishes for a couple months.
You could probably force it out with a funnel and a length of plastic tubing but I wouldn't bother.
TickMagnet
Aug 20, 2011 | Maytag Dishwasher
After the dishwasher is finished, the entire dishwasher is filled with soapy bubbles. Even I'd you do an extra rinse, this happens. Any ideas why.
This normally means that the soap cup dispenser is leaking jet dry into the dishwasher. Remove the screws around the door and it will come apart. The soap cup has a bracket that mounts it to the back of the door liner. Remove the bracket and change the soap cup. Its really a straight forward repair friend, good luck.
May 19, 2011 | LG LDF6920ST Stainless Steel 24 in....
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My dishwasher smells when the door is opened
Jet-dry sells a product that is supposed to clean dishwashers out.
You can try running an empty load with both soap compartments full of either vinegar OR Baking soda. DO NOT MIX BOTH.
May 25, 2010 | Asko D1976 Built-in Dishwasher
I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
the best way to use your dishwasher is the way it was designed.
if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
Feb 28, 2010 | Dishwashers
Machine wont empty properly pump seems to work. machine sounds like its operating normally bosch classixx dishwasher
dont use soap with jet dry or rinse aid in it. use regular cascade soap and fill completely with jet dry rinse agent. your unit is over sudzing .if this is helpfulto you send me a 4thumbs up post
Feb 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
Soap not breaking down in dishwasher
Be sure to run kitchen water hot at faucet before starting dishwasher or you will get an entirely cold water washer. Also be sure the jet dry dispenser is not empty. Only use liquid jet dry. Pay no attention if soap says with jet dry. Does not work as well. Hope this helps.
Jan 31, 2010 | Frigidaire 24 in. FDBB840DC Stainless...
We own a Bosch SHU5307UC dishwasher. Recently, during the 60 minute cycle, the foam builds up and at the end you can see all of it on the bottom. And the last minute dispaly stays on for a while. It...
the unit is over sudzing cut back on soap and dont clean dishes and then put them in dishwasher.dont use to much of the soap with jet dry. regular soap without jet dry in it then add and fill jet dry compartment
Dec 01, 2009 | Bosch SHU5307UC Built-in Dishwasher
Blue sticky spots in my dishwasher
some of the soaps out there are tempurture sensitive, several different ingrediants waiting on different temps during differnet times of the cycle,
I have seen this before or at least something similar,
does the soap your using now have the jet dry as part of it
if yes id go back to jet dry, your rinse cycle is not hot enough to fully disolve the jet dry in the soap, it gels and coaleses every where.
its designed to do that, so it will not just be washed down the drain on the wash cyle with the rest of the soap.....
Oct 11, 2009 | Dishwashers
Dishwashers Logo
716 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
