Question about Epson TM-T88III Thermal Printer
Epson tm88iv printing very slow
HELP i have a EPSON tm88iv which took me forever to install , now its install and working it takes about 45 sec to print a receipt.
i have tried printing from word pad and note pad , it print very fast from word pad but slow from note pad .
i am running a salon program called easy salon which i got loaded on a j2 touch screen unit .
is there a way of speeding up the printing of the receipt printing?
4 Suggested Answers
SOURCE: EPSON TM T88IV
The TM-T88IV printer is a thermal printer and does not have ink or a ribbon.
If the printer is not printing you may have the wrong type of paper in the printer. You must have thermal paper in order for the printer to work. Paper for a dot matrix printer will not work in this printer.
The printer has a self-test that you can perform by turning the printer off, holding down the Feed button and turning the printer on. A test strip will print. Press the Feed button again to print a longer test strip.
Posted on May 16, 2008
SOURCE: Epson M129H prints blank receipt
i need m129h driver
Posted on Apr 13, 2009
c-hom
  • 150 Answers
SOURCE: Epson TM-U220 Receipt Printer M188D Drivers
The driver for Epson printer has been
http://www.barcodesinc.com/epson/tm-u220-drivers.htm
Warm regards,
Anirban Mazumdar
Posted on Oct 08, 2009
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
EPSON L355
EPSON L355 EPSON Drivers and SW
Jan 27, 2014 | Epson Office Equipment & Supplies
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
Oct 14, 2009 | Epson STYLUS R230 InkJet Photo Printer
Print quality is poor on my Epson DX4000.
It maybe on it's way out ,they don't last forever but try epsoms solutions
https://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX4000-printer/Drivers-Support?target=article&extn=.html&articleId=1358
Jul 29, 2009 | Epson Office Equipment & Supplies
After installing the printer driver for EPSON TM88IV, the printers and faxes shows a status of not available.Help!
First step make sure you reboot after installation. If this does not correct the error then try disconnecting from computer and then reconnecting after about a minute. If this does not correct the problem then try unplugging the printer for about 30 mins and then reconnecting. This should wipe any stored info and allow you to start fresh. Also make sure this printer is set as the default printer. Hope this helps.
Jul 08, 2009 | Epson TM-T88III Thermal Printer
Slow getting to printer
1. Clean hard drive...Deleting temporary files, temporary internet files, etc.
(a good program is www.ccleaner.com )
2. Try defragging your hard drive.
Sounds like you don't have enough room for the print spooler.
May 14, 2009 | Epson CX8400 All-In-One InkJet Printer
Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Nov 08, 2007 | Epson Stylus Photo R340 InkJet Printer
The software that came with my scanner sometimes takes forever to respond.
Scott, Here you go: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58610&infoType=Overview I would first uninstall the scanner and unhook it completely. The download the update and re-install. Good Luck, Tim
Feb 05, 2007 | Epson Perfection 3590 Photo Flatbed...
Epson TM-T88III Thermal Printer Logo
711 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
