I can not open my front loader door i think it has the child proof lock on iit is a LG
  • Howard Galley May 11, 2010
    has it pumped out all the water from the washer?
    Top Expert:
  • Washing Mach... Master
  • 79,851 Answers
THE MACHINE HAS A PROBLEM WITH THE AUTOMATIC DOOR RELEASE THAT SHOULD UNLATCH THE DOOR AT THE END OF THE WASH CYCLE, THIS LATCH SOLENOID MAY BE DEFECTIVE OR STUCK
Posted on Sep 29, 2009
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
The child lock on my LG front loader washer is now at about 5 minutes each load. How can I SUCCESSFULLY turn the thing off???
i think your issue is either the door lock itself or the control panel. i would start by unplugging the unit(or tripping the circuit breaker), then hold in the power button for about 10 secs--this resets many LG washer's electronics. then plug back in an see if that helps. i do not think your issue is the child lock feature, but rather the safety door lock feature. good luck.
Sep 17, 2016 | LG Washing Machines
LG frontloader WD-1238c door locked
Unfortunately it as to be open from top take power off open top normally two screws at the back slide cover off look inside front loader for door catch unscrew and done open door replace with new one same model connect wires as disconnected take pics before disconnect screw it back on done.hope it helps you
Jan 10, 2018 | Washing Machines
My back doors wont open
If your back doors won't open from the inside then the child proof locks maybe turned on. Open the door from the outside and look at the edge of the door near the lock for a small lever or screw setting for the child proof lock. Tun off the child proof lock and then you can open the back door from the inside.
May 09, 2012 | Dodge Cars & Trucks
Child proof locks kangoo how to unlock
Open the door and look at the back edge of the door by the latch there will be a small sliding lever to enable/disable the child lock.
Mar 10, 2012 | Renault Kangoo Cars & Trucks
My neptune frontend loader will flash the door lock for 2 seconds and then it will go off when ever i start the machine, i think my child opened it with out turning it off.. is something broken
HI- It is possible that the door lock was damaged if someone forced it open mid-cycle. The machine will not cycle unless the door lock engages. Will probably need a to get a Tech out to have a look. Good luck.
Sep 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do i remove child lock on samsung front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 05, 2009 | Samsung Washing Machines
Right Rear door will not open from exterior or interior.
Took off inside door panel and flipped the child proof lock. Mechanism for entrance from outside handle broken. Replacing it.
Nov 29, 2008 | 1992 Lincoln Continental
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
304 people viewed this question
Top Washing Machines Experts
