Question about Black & Decker WM225 Workmate 225 Portable Project Center
Black slides on wood ,where do they go
I have a black and decker workmate 300 and replaced the wood but forgot how to install the plastic slides on the wood. Can't find the manual to visualize which slide goes where.
  • 101 Answers
You can go to your local hardware store "Home Depot, Ace" or where you bought it and maybe they will have a model to look at or you can look at the packaging ...Good Luck
Posted on Sep 29, 2009
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Black decker instructions
https://www.youtube.com/watch?v=DTB1llv3iF0
Jul 13, 2014 | Black & Decker Workmate 375 with Hand...
Workmate 350 manual
Please contact Black and Decker on this manual. we do not have it.
Nov 06, 2012 | GPS
Assembly instructions
hello kevin, to get your manual you are going to have to go to black & decker.com workmate instruction manual model WM225,to download and print,hope this helps,
Jan 28, 2012 | Garden
Need user manual for Black and Decker Workmate 425 type 2
Hi Dee,
Black and Decker Workmate 425 type 2 seems unavailabe
[only parts digarams] online but here's the instructions manual in pdf for Workmate 425 type 5 from
www.blackanddecker.com/power-tools/WM425.aspx
Hope this helps.Thanks!
Please vote this answer if helpful.
Dec 18, 2011 | Garden
I have a workmate 350 . I inherited it without a manual. Can't figure out how to fold it up.
There is no Workmate 350. Your model is the Workmate 125. See Black & Decker web site for manual Workmate 125
Jun 10, 2011 | Black & Decker Garden
I am looking for a manual for a Black and Decker Workmate 450.
I'm assuming that you ar talking about WM225 450 Pounds, check in THIS LINK.
Hope helps.
Sep 08, 2010 | Black and Decker WM125 Workmate
Do you have assembly instructions
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90555796,WM125.pdf
Aug 23, 2010 | Black and Decker WM125 Workmate
Hi Ihave an old all alluminium wm325 b&d workmate, I am looking for 4 round plastic/rubber feet for it, this was bought in in the mid 70s
Chances of finding the original parts are slim at best. Check with some store like Lowes--they have an amazing proliferation of plastic/rubber feet in many sizes. Good luck!
Aug 13, 2010 | Black & Decker Garden
Black & Decker WM225 Workmate 225 Portable Project Center Logo
392 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Rabbit Brains
Rabbit Brains
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
